DISCARDED: SMath Studio 0.99.6647 (14 March 2018)
DISCARDED: SMath Studio 0.99.6647 (14 March 2018) - Сообщения
#1 Опубликовано: 13.03.2018 14:25:12
Группа: Super Administrator
Скачать
SMathStudioDesktop.0_99_6647.Mono.tar.gz (1,28 МиБ) скачан 2552 раз(а).
SMathStudioDesktop.0_99_6647.Setup.msi (2,15 МиБ) скачан 4826 раз(а).
SMathStudio 0.99.6646 and 0.99.6647 discarded due to serious bug with colapsed areas, which could damage your worksheet data.
Sorry for inconvenience. Working to fix it asap!
10 пользователям понравился этот пост
Василий Николаевич Храмушин 13.03.2018 14:43:00, Arie 13.03.2018 14:44:00, uncblue 13.03.2018 15:00:00, sergio 13.03.2018 15:41:00, Igor Skarine 13.03.2018 17:33:00, frapuano 13.03.2018 20:08:00, Вячеслав Мезенцев 13.03.2018 23:59:00, NDTM Amarasekera 14.03.2018 01:39:00, Radovan Omorjan 14.03.2018 04:00:00, Davide Carpi 14.03.2018 09:04:00
#2 Опубликовано: 13.03.2018 14:42:01
Arie
Arie
uMath Files Plugin appears to be broken with new release.
#3 Опубликовано: 13.03.2018 14:58:12
Thank you! Fixed and new plug-in version uploaded.
#4 Опубликовано: 14.03.2018 12:53:10
Updated version released: SMath Studio 0.99.6647.
#5 Опубликовано: 14.03.2018 13:18:53
The result formatting options of math regions aren't saved or handled correctly, see SS-3515.
#6 Опубликовано: 14.03.2018 13:48:34
Jason McCool
Jason McCool
9 сообщений из 78 понравились пользователям.
Area controls seem to have been adversely affected with this build. A worksheet I have where a lot of the calcs are hidden inside separate areas to allow for the option of a "summary" calc or a "detailed" calc opened up almost completely unreadable. It appears the contents of the collapsed areas are being displayed over the top of each other all in 1 line instead of being hidden inside the area. See the attached screenshot. Also experiencing some instability when trying to click on the area "+" signs to expand them. The areas don't expand, and instead completely disappeared once. Deleting one area at the end of the worksheet deleted all the calcs (4 pages with all areas collapsed, 10 or so pages fully expanded) except for the part that had been inside the first collapsed area on the first page.
Thanks,
Jason
Davide Carpi 14.03.2018 13:53:00
#7 Опубликовано: 14.03.2018 14:10:28
Please could you send a file to me by e-mail to fix? I cannot reproduce this issue on any of my worksheets.
#8 Опубликовано: 14.03.2018 16:24:20
I experienced problems similar to those of Jason.
In my case, when the sheet is opened, the problem does not exist but after saving the sheet, after closing it and finally reopening, problems with the collapsed areas occur.
#9 Опубликовано: 14.03.2018 16:25:20
Jason McCool
Jason McCool
Sorry, I forgot to check to get responses by email when I posted earlier. Here you go
C6 Channel Shear Tab.sm (228,91 КиБ) скачан 1685 раз(а).
#10 Опубликовано: 14.03.2018 16:31:45
Jason, I see this file was saved by SMath Studio 0.99.6646.16669 and already have problems.
Do you have the initial version?
#11 Опубликовано: 14.03.2018 16:33:56
Sergio, seems this is very important issue. And bug is in saving logic.
Please could you provide any file which gives this error on save?
Thanks in advance!
#12 Опубликовано: 14.03.2018 16:46:23
Jason McCool
Jason McCool
I actually hadn't meant to be using beta versions on my production work, but I apparently unchecked the "exclude beta versions" at some point recently and had saved that worksheet in build 6646. It seemed to work well yesterday, and I have a pdf printout that doesn't show any issues with the display of the collapsed areas, but that was printed to pdf prior to saving and closing, so perhaps it is the same behavior as for Sergio. I had to finish getting some calcs ready for a client today, so I reinstalled the last stable build from the website this afternoon, and can't confirm the behavior now with any of the beta builds. But here is the original worksheet that works in build 6622. Thanks!
Jason
Channel Shear Tab.sm (228,88 КиБ) скачан 1656 раз(а).
#13 Опубликовано: 14.03.2018 16:46:36
Thank you Jason and Sergio!
I've reproduced this issue and it is introduced exactly in 0.99.6646.
I'm working to figure out the reason and fix it asap.
The following SMath Studio nightly builds are marked as NOT APPROVED and will not be suggested to download to anyone anymore: 0.99.6646, 0.99.6647!
Показать спойлер
Thank you very much for the report and your help!
Jason McCool 14.03.2018 16:48:00
#14 Опубликовано: 14.03.2018 16:52:50
prova1.sm (2,87 КиБ) скачан 1629 раз(а).
it's a trivial file. When I saved it, it appeared correctly but if I open it, the error occurs on the collapsed area
