1 страниц (15 вхождений)
2D Plots - What am I missing? - Сообщения
Trying to plot a variety of functions and nothing shows up in the plots.
I have 23 yrs of MathCad experience, but cannot figure out what Smath is looking for to plot three very simple function (See attached file).
Additionally, I am not sure why an equation needs vectorized to output the answers in the normal distribution equation.
Equation 1 - Normal distribution does not solve as a function until it is vectorized. Why?
Equation 2 - f(x):x^3+2*x*sin(0.25) solves without vectorization but will not plot. Why?
Equation 3 - f(x):vectorize(1/{σ*sqrt(2*π)}*e^{-1/2*({x-μ}/σ)^2}) solves with vectorization but does not plot (2D or X-Y plot method). Why?
Smath - 2D Plots.sm (15,56 КиБ) скачан 1239 раз(а).
Equation 2 also needs vectorized to get the correct results.
You don't have to do this in MathCad, why here?
First Solution Found
This allowed me to plot Normal Distribution Function.
augment(x,f(x))
augment(x,f(x))
Solved for now. On with the learning experience.
Thanks....
Thanks....
Hi, if you need a quick plot I recommend you use 2D standard plot you can plot functions f(x) directly , if you need a more configurable plot use XY plot but you need to put your data in a special format. Файл не найден.Файл не найден.
WroteTrying to plot a variety of functions and nothing shows up in the plots.
1. Show the two other ones on same document for doctoring.
2. Your sigma makes no sense !
3. BTW, in Samples you should find my Stat Treasury [10 WS]
Hard to find such immense Compendium.
4. If you can't download, please let me know
Welcome ... Jean.
Smath - 2D Plots.sm (17,77 КиБ) скачан 1238 раз(а).
... besides the pure statistical application,
you can use to fit data sets [Fréchet US Rainfall ...]
Wrote... besides the pure statistical application,
There is about 24 built-in PDF in Smath ... f(x) menu
as well as CDF, ICDF
Paecific.sm (9,62 КиБ) скачан 1250 раз(а).
... in most applications inc(Low,High,step,f(#)) is preferred
Paecific.sm (14,25 КиБ) скачан 1278 раз(а).
