The Maxima Solver can't solve the symbolic equations
The Maxima Solver can't solve the symbolic equations - Сообщения
#1 Опубликовано: 19.02.2022 04:35:04
netsonicyxf
netsonicyxf
2 сообщений из 79 понравились пользователям.
2.sm (3,15 КиБ) скачан 1345 раз(а).
#2 Опубликовано: 19.02.2022 21:42:42
netsonicyxf
netsonicyxf
Thanks Jean,
Both a and alpha are unknows.
the result of a and alpha are still includes these unknows.
Only φ, R and m are knowns and can be used in the results.
#3 Опубликовано: 20.02.2022 10:12:56
netsonicyxf
netsonicyxf
Thanks Jean,
Buy you 2nd sybolic solution is the same as the 1st one.
The solution should not include the unknow a and alpha
My friend use Maple to get symbolic solution like this
You can see that in the solution of alpha, there is no a, in the solution of a, there is no alpha.
#4 Опубликовано: 20.02.2022 20:29:51
Symbolic solver of maxima is not that capable.
As far as I know of course, maybe there is a simpler way.
But this statement was what I had read about it.
You have to use some substitutions for that solutions.
And some extra division, arc functions, visa versa.
Here is α solved symbolically in wxMaxima.
Same method can be applicable for variable a.
untitled.wxmx.zip (1,6 КиБ) скачан 399 раз(а).
netsonicyxf 20.02.2022 22:08:00
#5 Опубликовано: 21.02.2022 17:52:40
Maxima and Maple have same ancestor Macyma
This is a misinformation, you are wrong as usual Jean.
Macsyma is not ancestor of Maple, or Maple is not a derivative of Macsyma.
Those are totally different softwares, written in different programming languages.
Written in different purpose, in different places by different people.
Macsyma is written in LISP, Maple is in C and Java.
It was developed to work on lower cost computers, entirely from scratch.
It could run on cheap machines because of C, on the contrary of LISP.
Maxima is written in LISP but it has a different background.
Maxima is not a successor of Macsyma, it started as 1982 version of it.
Macsyma is developed to 1999, than sold and not a version is released after.
Maxima code was property of US Department of Energy, maintainer made it GPL in 1998.
That code is being developed by independent maintainers since than, it is not just free but open-source.
Maxima does not include any of the many modifications and enhancements made to the commercial version of Macsyma during 1982–1999.
And that file at the end of you post, it tells nothing.
Nothing about what the topic owners requests.
Just a waste of server space and people's time.
#6 Опубликовано: 22.02.2022 03:12:53
netsonicyxf
netsonicyxf
Is Maple plugin in Smath able to get symbolic results as Maxima does, but more easily?
#7 Опубликовано: 22.02.2022 11:55:34
Maple is easier to use, that is a fact.
And sometimes it gives better results.
But Maxima can surpass Maple at certain aspects.
Use what suits your needs most.
In the example below, I solved your function with Maple.
Though it gives the results correct, result matrix is cripled.
Copying and changing last bits of result ";2;1)" to ";2;2)" will correct the result.
";" may differ to "," according to your arguments separator.
Worksheet1.sm (15,97 КиБ) скачан 1349 раз(а).
Click to Enlarge
netsonicyxf 26.02.2022 22:43:00
#8 Опубликовано: 16.04.2022 03:36:27
netsonicyxf
netsonicyxf
Click to Enlarge
Hi overload,
When I open you sm I get this error
#9 Опубликовано: 16.04.2022 09:57:28
netsonicyxf
netsonicyxf
... is that what you are looking for ?
No
The two equations should be put in one system.
#10 Опубликовано: 16.04.2022 12:26:22
churichuro
churichuro
29 сообщений из 79 понравились пользователям.
Hi overload,
appears in red, because the evaluation must be symbolic.
select the "result" variable, press the right button and in the type of evaluation select symbolic and that's it.
I hope I have served you, greetings
#11 Опубликовано: 16.04.2022 12:43:00
Hi. Another way, applying trigonometric identities.
solve_trig.sm (12,03 КиБ) скачан 1292 раз(а).
#12 Опубликовано: 17.04.2022 08:32:35
Thanks Jean,
Both beta and alpha are unknown.
the result of beta and alpha still include these unknowns.
Onlyφ, R and m are known and can be used in the results.
... to be used as productive.
Your system is baby stuff, example 2 advanced.
I leave it there, not knowing more about your end demand.
Simply a solved formula representation ???
Comment or ignore ... Jean.
Solve ADVANCED Productive.sm (22,64 КиБ) скачан 1321 раз(а).
#13 Опубликовано: 17.04.2022 09:52:57
Does it conclude something in that long journey ?
#14 Опубликовано: 17.04.2022 10:23:25
Addition to churichuro's reply, use this simple function to correct maple plugin result matrices.
maplecorrect.sm (26,79 КиБ) скачан 1906 раз(а).
