dB - How to work with dB in SMath - Сообщения
#1 Опубликовано: 30.04.2023 14:11:11
Valery Ochkov
Valery Ochkov
67 сообщений из 716 понравились пользователям.
Preamble
Cut me into pieces, eat me with butter, but if I want to get a decimeter, I divide the meter by 10, not multiply the meter by 10. If I multiply the bel by ten, then I get a decabel, not a decibel.
I can work with dB in Mathcad 15. How to work with dB in SMath?
#2 Опубликовано: 30.04.2023 18:18:45
I can work with dB in Mathcad 15. How to work with dB in SMath ?
Simple example attached.
Cheers ... Jean.
Inst_dB Sound Copy.sm (142,11 КиБ) скачан 1405 раз(а).
#3 Опубликовано: 30.04.2023 19:05:14
If Davide could provide operator forms for To_dB() and From_dB() then this could pretty much look like in Mathcad.
dB.sm (9,61 КиБ) скачан 1341 раз(а).
#4 Опубликовано: 01.05.2023 03:04:21
Valery Ochkov
Valery Ochkov
Cheers ... Jean.
Thanks,
but how can I see your plot without any formatting?
#5 Опубликовано: 01.05.2023 03:06:58
Valery Ochkov
Valery Ochkov
Thanks,
But how can I use the postfix and prefix operators in SMath? Is there a tree operator too?
#6 Опубликовано: 01.05.2023 09:25:12
but how can I see your plot without any formatting ?
Try to zoom your document in native Smath 100 %
#7 Опубликовано: 01.05.2023 11:11:33
That's what you should have.
#8 Опубликовано: 01.05.2023 16:02:21
Thanks,
Davide Carpi has defined operator representations for some functions in his Custom Glyphs plugin. So he is the wizard who can make that happen if you convince him. He also implemented the Glyph for the Maxima().
The drawback is that users can easily read these expressions but it is hard to guess how to write these operators if you aren't aware of the background function used for it. So the best would be to have a side panel (as it is implemented for the currency units plugin).
#9 Опубликовано: 01.05.2023 16:09:47
Valery Ochkov
Valery Ochkov
Sorry, but same result.
#10 Опубликовано: 01.05.2023 18:15:19
Seems something related to DPI scaling in the plugin. Just a guess.
#11 Опубликовано: 01.05.2023 19:20:47
Originally Posted by: Jean Giraud [/url]Originally Posted by: OchkovVF [url=/forum/yaf_postsm81092_dB.aspx#post81092]but how can I see your plot without any formatting ?
Rewrite the code on your system.
