Дополнение ODESolvers
Дополнение ODESolvers - Численное решение систем ОДУ. Intel ODE Solvers Library. - Сообщения
#1 Опубликовано: 09.11.2010 14:56:56
уни
уни
156 сообщений из 355 понравились пользователям.
Список функций:
rkfixed(), Rkadapt(),
rkm9st(), mk52lfn(), mk52lfa(), rkm9mkn(), rkm9mka().
Решатели нежёстких систем ОДУ:
rkfixed(init, x1, x2, intvls, D) Uses the fourth-order Runge-Kutta fixed-step method.
Rkadapt(init, x1, x2, intvls, D) Uses the fourth-order Runge-Kutta with adaptive step-size.
Intel ODE Solvers Library:
rkm9st(init, x1, x2, intvls, D) A specialized routine for solving non-stiff and middle-stiff ODE systems using the explicit method, which is based on the 4th order Merson’s method and the 1st order multistage method of up to and including 9 stages with stability control.
mk52lfn(init, x1, x2, intvls, D) A specialized routine for solving stiff ODE systems using the implicit method based on L-stable (5,2)-method with the numerical Jacobi matrix, which is computed by the routine.
mk52lfa(init, x1, x2, intvls, D) A specialized routine for solving stiff ODE systems using the implicit method based on L-stable (5,2)-method with numerical or analytical computation of the Jacobi matrix. The user must provide a routine for this computation.
rkm9mkn(init, x1, x2, intvls, D) A specialized routine for solving ODE systems with a variable or a priori unknown stiffness; automatically chooses the explicit or implicit scheme in every step and computes the numerical Jacobi matrix when necessary.
rkm9mka(init, x1, x2, intvls, D) A specialized routine for solving ODE systems with a variable or a priori unknown stiffness; automatically chooses the explicit or implicit scheme in every step. The user must provide a routine for numerical or analytical computation of the Jacobi matrix.
Параметры:
- init is either a vector of n real initial values, where n is the number of unknowns (or a single scalar initial value, in the case of a single ODE - not implemented yet).
- x1 and x2 are real, scalar endpoints of the interval over which the solution to the ODE(s) is evaluated. Initial values in init are the values of the ODE function(s) evaluated at x1.
- intvls is the integer number of discretization intervals used to interpolate the solution function. The number of solution points is the number of intervals + 1.
- D is a vector function of the form D(x,y) specifying the right-hand side of the system
Показать спойлер
ODESolvers. Example 1.png ODE-Lorentz-uni.png ODESolvers. Van der Pol oscillator.png
Ссылки:
1. Intel ODE Solvers Library.
ODE_manual.pdf (239,74 КиБ) скачан 1064 раз(а).
Россия навсегда! Вячеслав Мезенцев
Mikka 10.11.2010 06:47:00
#2 Опубликовано: 09.11.2010 17:04:37
Valery Ochkov
Valery Ochkov
66 сообщений из 684 понравились пользователям.
Текст функции rkfixed
http://communities.ptc.com/videos/1471
Текст функции rkadapt
http://twtmas.mpei.ac.ru/mas/worksheets/rkadapt.mcd
если это кому интересно.
#3 Опубликовано: 10.11.2010 02:31:53
уни
уни
Спасибо, Валерий Фёдорович, приму во внимание.
Вот плагин с функцией rkfixed(): ODESolvers.dll
Исходник: ODESolvers_Class1.pdf
Вот примерный документ: rkfixed.sm
Примечания:
1. Функция системы должна быть вектором.
2. Имена переменных (t,x) могут быть любыми.
П.С. Там в цикле while() есть небольшая ошибка.
Поскольку это всё равно транслятор, то работает относительно медленно.
Самое смешное, что аналогичная функция, написанная в документе в виде программного блока работает всего на немного медленнее этой реализации ("подушка" посчиталась на 30 секунда быстрее, всего время расчёта для rkfixed() на моём компе около 3 мин 10 сек).
if ( система[n].Equals( перем_x ) && система[ n + 2 ].Equals( Элемент ) )
Здесь (n+2) теоретически может превысить размер вектора элементов системы. Надо будет поправить на досуге.
Mikka 10.11.2010 06:47:00, GhostTraktor 11.12.2011 04:15:00
#4 Опубликовано: 10.11.2010 04:58:34
2 334 сообщений из 4 026 понравились пользователям.
Группа: Super Administrator
Спасибо за плагин.
Личным сообщением на форуме послал Вам логин и пароль для доступа к репозиторию на запись. Думаю удобнее код будет иметь там.
уни 10.11.2010 05:46:00
#5 Опубликовано: 10.11.2010 05:44:27
уни
уни
Да, я заметил логин и пароль, спасибо. Пока не буду мусорить в репозитории. Последний год я привык писать на русском (пишу в одиночку), а в репозиторий нужно переписывать всё на английском. Пока лень.
Если добавить ещё несколько решателей, то, пожалуй, можно будет их залить. Меня не устраивает скорость работы. Всё равно медленно.
#6 Опубликовано: 11.11.2010 16:27:18
уни
уни
В качестве тестовой версии предлагаю Rkadapt(). Исходник является компиляцией кода Валерия Фёдоровича и приведённого в книжке "Numerical Recipes in C", откуда он собственно и был взят. Я подгонял его под фиксированные шаги как в Маткаде, чтобы вызов их был идентичен. Получилось не совсем ещё хорошо, но пока работает.
Примечание. Возможны случаи при большом количестве шагов (больше 100, к примеру), когда в конце вектора решения будут один или несколько нулей.
Плагин: ODESolvers.dll
Документ: Rkadapt.sm
#7 Опубликовано: 12.11.2010 05:14:06
уни
уни
Лучше тестируйте вот эту версию: ODESolvers.dll От 12.11.2010 г.
Здесь я уже понял ту фишку, которую использовали маткадовцы, когда адаптивный шаг "пристраивали" к фиксированной сетке. Работает гораздо быстрее и правильнее. Убрал многие ошибки. Теперь получается тоже, что и с rkfixed(), но гораздо точнее в тех же точках.
#8 Опубликовано: 12.11.2010 08:51:13
уни
уни
Андрей, тут я заметил одну проблему, когда правил плагин:
#9 Опубликовано: 12.11.2010 10:35:29
Функция if разбирается только в Preprocessing и не определяется в численной и/или символьной библиотеках.
#10 Опубликовано: 12.11.2010 12:31:30
уни
уни
Да, это даже наверное логично. Исправил плагин: ODESolvers.dll
Алгоритм Rkadapt(): Rkadapt prog.sm
К сожалению, я не смог заставить его работать, т.к. не понял где ошибка в записи выражения.
Здесь ещё нет защиты от зацикливания при выборе шага.
Ещё пример работы:
nickgoblin 31.01.2011 17:26:00
#11 Опубликовано: 12.11.2010 15:25:02
уни
уни
Эксперименты с ушами:
#12 Опубликовано: 14.08.2013 05:01:07
уни
уни
Обновлён. Добавлены функции из Intel ODE Solvers Library: rkm9st(), mk52lfn(), mk52lfa(), rkm9mkn(), rkm9mka().
Также как и в DotNumerics можно использовать переменные AbsTol и RelTol в документе для задания точности вычислений.
ODE_manual.pdf (239,74 КиБ) скачан 841 раз(а).
Fridel Selitsky 14.08.2013 05:26:00
