3D Plot Region
3D Plot Region - CreateMesh() and 3D Plot - Сообщения
#21 Опубликовано: 27.03.2014 02:36:04
Fridel Selitsky
Fridel Selitsky
Try method
http://en.smath.info/forum/yaf_postst2215_Transferring-three-dimensional-image-on-a-two-dimensional--flat--graph-by-prof--A-B-Ivanov.aspx
rod_spring1.sm (46,6 КиБ) скачан 1709 раз(а).
#22 Опубликовано: 08.04.2014 07:41:01
fdufnews
fdufnews
am I wrong or the x and y axis are exchanged?
I have downloaded smath studio a few days ago and made some examples to be more familiar with the program. Today I have tested 3D plot and found 2 strange behaviour.
First on 3D plot x and y seems to be swapped
Second the same formula plotted by 3D plot and by 3D graph give a different view
#23 Опубликовано: 08.04.2014 08:59:12
The SMath built-in 3D plot is left-handed, the 3DPlot Region is right-handed (being able to choose, I prefer the 2nd but is matter of taste)
#24 Опубликовано: 08.04.2014 15:40:08
fdufnews
fdufnews
Thanks for answering.
But the sin function is defined with y as variable and the step function is defined with x as variable. On the 3D plot the sin is along the X axis and the step function along the Y one.
#25 Опубликовано: 17.01.2016 17:10:32
zoom
zoom
2 сообщений из 7 понравились пользователям.
is there a version of a tutorial for dummies for this plugin? I tried to figure it out on my own but can't get it to work.
I just wanted to try and plot a sphere for fun. maybe next would be plot a line / plane and see where it intersects the sphere.
#26 Опубликовано: 18.01.2016 00:26:12
I just wanted to try and plot a sphere for fun.maybe next would be plot a line / plane and see where it intersects the sphere.
______________________________
AFAIK, as far as I have experimented, the Maxima 3d plot is for parametric unctions
and the style in example. It does not plot "volume 3D", it does not take stacked arguments. Up until my help: zap for the sphere and the cutting plane. The 3D Smath default plot is just for fun, nothing to do, no color ... These two may help using this Maxima plot.
Contour X_Y plot.sm (56,37 КиБ) скачан 1714 раз(а).
Contour X_Y plot [More Parametric].sm (103,25 КиБ) скачан 1522 раз(а).
#27 Опубликовано: 28.12.2018 17:20:33
Updated.
Changes:
- CreateMesh(): (u,v) can be skipped for the function;
- 3D Plot Region: began updating the code (draft version).
#28 Опубликовано: 28.12.2018 17:36:11
About 3D Plot. Unfortunately, the source code that I found requires significant improvement in order to display a family of graphs. I hope I have enough time and desire to bring this component to normal at last.
Davide Carpi 31.12.2018 10:48:00, Radovan Omorjan 29.12.2018 03:38:00, frapuano 28.12.2018 19:44:00
#29 Опубликовано: 02.05.2020 19:57:40
Alvaro Gavilán-Rojas
26 сообщений из 68 понравились пользователям.
I really need this amazing plug-in to plot around a million independent points, but I am having this issue with the installation. Could someone help me?
Thank you in advance.
#30 Опубликовано: 03.05.2020 09:33:33
ONE million independent points,
plotted on device at eye resolution 1000000/1200=833 inches
plotted at PC screen resolution 1000000/96=10417 inches
#31 Опубликовано: 04.05.2020 16:06:43
Unfortunately, I cannot build a project on the server. We will wait for an answer from the author of the program. As for the plugin itself, it is not yet complete. Displaying data is not intuitive.
#32 Опубликовано: 04.05.2020 16:23:58
1. ONE million data from surface f(x,y) ?
2. ONE million data as image: Gray scale, RGB ?
Not yet like the English dog.
If it looks like a dog, walks like a dog,
barks like a dog => it is a dog [big, small ?]
#33 Опубликовано: 06.05.2020 17:03:09
You can create one million square matrix [1000x1000]
One million single vector from source has immediate meaning
from Fourier spectrum.
One million XY double vector is for XY plot.
Single Y, double XY imported from source ?
One million matrix [square/rectangular] ... from source ?
Two many unknowns for help !
OneMillion.sm (36,31 КиБ) скачан 1675 раз(а).
#34 Опубликовано: 06.05.2020 18:35:43
OneMillion Rectangular.sm (15,58 КиБ) скачан 1620 раз(а).
#35 Опубликовано: 10.05.2020 18:23:35
Thank you uni and Jean for your answers, now I reviewed my problem. Fortunately I have already installed the 3D Plot Region plugin (99.7030 SM version). I don't know why "plug-in installation failed" last week, but now that problem is solved.
What I understand for the 3D plot region is that you need a function to be plotted, and please correct me if I am wrong. I was reviewing your image creation files Jean, and was very helpful for me to know those functionalities, but in my case, I have a 3D graph more like "scatter plot".
Here, for example, I generate a random matrix 10x3 of ten points in x,y,z coordinates. In the included default 3D plot, it seems that I cannot delete the line between points (I want only the points to be displayed), and also I cannot extend the axis coordinates to verify the coordinates for a point. It looks like the coordinates are reversed, since there is no point plotted in the x+,y+,z+ region (and that region should be the only one with plotted points). Also it seems to be totally out of range because my axis values are around 50000 and I have values no greater than 50.
I hope you can help me, or if you know that I could do this sort of plots in another program but from SMath (I begin to know about Maxima, for instance).
Thank you both again!
SMath:
Mathcad:
SMath file:
Scatter plot.sm (4,54 КиБ) скачан 1629 раз(а).
(sorry for the too large images, I don't know how to change that)
#36 Опубликовано: 10.05.2020 19:31:15
Now this component cannot be fully used for your purposes. Point visualization is not implemented. I am still looking for time to study the theory of three-dimensional graphics. Unfortunately, the limitations do not allow the use of free components. Writing everything from scratch is a time consuming task.
frapuano 11.05.2020 04:01:00
#37 Опубликовано: 10.05.2020 19:52:05
Ok, thank you very much uni. In the meantime, I will try to somehow export my matrix to Scilab, where I previously worked with 3D scatter plots. Anyways, I am amazed by the other plotting capabilities (right now reading the SMath Einführung).
A big thank you for your plugins.
#38 Опубликовано: 11.05.2020 00:32:50
Fridel Selitsky
Fridel Selitsky
A three-dimensional image can be displayed on a flat graph
https://en.smath.com/forum/yaf_postsm12626_3D-Plot-Region.aspx#post12626
Scatter plotM.sm (13,56 КиБ) скачан 1652 раз(а).
#39 Опубликовано: 11.05.2020 10:35:17
Thank you Ber7 for recalling your previous post. Awesome 3D animations. I will certainly use this method to convert 3D to 2D and will give a try for animation on my scatter plot.
#40 Опубликовано: 11.05.2020 11:54:16
Inspired from Ber7:
otherwise => scaled/populated/oriented
Not yet done Higgs Boson !!!
Page4 Scatter 3D.sm (19,31 КиБ) скачан 1787 раз(а).
