Engineering evaluation
Engineering evaluation - need for better graphing ... - 消息
#1 已发布: 2015/11/30 13:20:40
Teacher
Teacher
1个赞,共20个帖子。
Hi there,
I'm an mechanical engineer dealing with many different design layout problems.
Request #1:
A I often have to do is displaying internal force systems alont a part. Though the given functions are just piecewise defined and the trailing variable is starting every time new.
Up to now I do the graphing "by hand" in just defining the results point to point .... Woould be nice to get a more easier way to do so ...
Request #2:
Is'nt it possible to intergate the XY-Plot plugin and enhance it a little bit in
- giving it a more friendly GUI for modifying the way of displaying the results
- giving it the possibility to draw an vector-array (4xn) like
(V1x.start, V1y.start, V1x.end, V1y.end
V2x.start, V2y.start, V2x.end, V2y.end
Request #3:
Sometimes I need to display 3D-Surfaces and Vectors. The scope of doing so in SMath are very litte, so it would be great to improve it!
Hope that I'm not the only one who is in need of those things ...
#2 已发布: 2015/11/30 17:06:32
Ernesto
Ernesto
13个赞,共74个帖子。
For Request 1,
Have you tried creating a piecewise function, and later plotting that?
#3 已发布: 2015/12/23 14:44:02
983个赞,共6,866个帖子。
_____________________________
Posting your work sheet is almost garantee to get reply.
Get inspired from the attached.
Utilities Matrix Treasury [Rotate].sm (48.29 KiB)已下载 1361 次。
Utilities [Plot points on Trace].sm (13.08 KiB)已下载 1416 次。
Integrate Discontinuous.sm (24.9 KiB)已下载 1499 次。
Utilities XY plot.sm (16.5 KiB)已下载 1547 次。
LGC Logistic.sm (37.77 KiB)已下载 1571 次。
Utilities Quick f plot.sm (41.66 KiB)已下载 1595 次。
Contour X_Y plot.sm (55.83 KiB)已下载 1528 次。
Contour X_Y plot [More Parametric].sm (101.88 KiB)已下载 1384 次。
3位用户喜欢此帖子
ioan92 2015/12/23 14:51:00, Radovan Omorjan 2015/12/23 17:37:00, Andrey Ivashov 2016/1/14 12:52:00
#4 已发布: 2016/1/12 13:39:32
Teacher
Teacher
1个赞,共20个帖子。
Hi there,
sorry, forgot to add example.
Here we go. Its about constructing a lever of an container vehicle.
On page 3 there are two "Bereiche" where there are different functions for the bending gear Mb and below that there is a Diagramm...
Container Vehicle.doc (768.5 KiB)已下载 988 次。
calculations.sm (844.92 KiB)已下载 1584 次。
#5 已发布: 2016/1/13 13:09:57
Ernesto
Ernesto
13个赞,共74个帖子。
There are only 2 pages to this document, there is no page 3. please repost
#6 已发布: 2016/4/9 18:20:44
Teacher
Teacher
1个赞,共20个帖子。
Hi, sorry I just posted the tasks not the calculations .... So I've done that now in the addition to the post abovs.
