how to plot discrete function
how to plot discrete function - 消息
#1 已发布: 2022/11/8 14:37:51
Mo
Mo
0个赞,共34个帖子。
hi,
I am trying to create a sheet to design welds and want to plot the geometry of the weld lines.
the problem is if I assign a matrix with x,y coordinates the 2D plot will draw a continuous function connecting all points, and when I assign this to a discrete matrix of line coordinates it does not plot unless I assign each line individually which is bad as I want it plotted based on the geometry.
in the example below, I want the 2D plot to plot LW without manually adding each component of LW individually.
未找到文件。未找到文件。
Thanks
#2 已发布: 2022/11/8 15:18:08
Arie
Arie
94个赞,共285个帖子。
One possible options mat2sys.1() function.
test_alyles.sm (35.91 KiB)已下载 1308 次。
sergio 2022/11/8 15:53:00
#3 已发布: 2022/11/8 15:48:06
Mo
Mo
0个赞,共34个帖子。
Many thanks, alyles!!
#4 已发布: 2022/11/8 16:20:38
983个赞,共6,866个帖子。
... make it algo style. CG can be managed as well.
#5 已发布: 2022/11/8 16:51:40
983个赞,共6,866个帖子。
... it may be possible to make svg [Scale Vector Graphic].
Cheers ... Jean.
test_alyles & jean.sm (41.37 KiB)已下载 1288 次。
#6 已发布: 2022/11/8 20:36:11
983个赞,共6,866个帖子。
... this is NOT a graph. It is an image triplet.
1. You can size the thickness/magnitude of the CG
2. You size length/thickness/color of the side welds
3. re-dispose the final triplet.
Cheers ... Jean.
#7 已发布: 2022/11/8 22:08:39
983个赞,共6,866个帖子。
... here is the project as offered.
Utilities Discrete COMPANION_2 WELD.sm (20.2 KiB)已下载 1325 次。
#8 已发布: 2022/11/9 05:42:29
1,362个赞,共2,276个帖子。
You might consider building geometry plots from the pre-defined objects in the XY-Plot-plugin.
4位用户喜欢此帖子
sergio 2022/11/9 07:36:00, NDTM Amarasekera 2022/11/9 09:42:00, Arie 2022/11/9 09:42:00, Alvaro 2022/11/9 18:32:00
#9 已发布: 2022/11/9 18:34:13
1,139个赞,共1,805个帖子。
You might consider building geometry plots from the pre-defined objects in the XY-Plot-plugin. ...
And maybe you may be interested in this other Martin' post, if you want to draw steel profiles to be welded, and by the way calculate their mechanical parameters: https://en.smath.com/forum/yaf_postsm78221_Split-Areas-Polygons-convex-and-concave--by-lines.aspx#post78221
