1页(7条)
how to use the "system of equations" function - 消息
Wrotehow to get the result of x, y without using the matrix? I tried solve and findroot, but can't get the value of x, y.
You can't use solve() for nonlinear equations. (more than one unknowns)
You can use roots(), FindRoot() or al_nleqsolve().
Here is your equation solved in various ways.
solvers.sm (10.77 KiB)已下载 1317 次。
Excellent reply!
FindRoot is better for my condition, I need units.
Thanks Overlord!
Thanks Overlord!
WroteWrotehow to get the result of x, y without using the matrix? I tried solve and findroot, but can't get the value of x, y.
Thank you, Jean, you're right, I need more practice.
WroteWrotehow to get the result of x, y without using the matrix ?
Matrix style is more commonly encountered in Engineering projects.
That add-on will enrich your future projects.
1页(7条)
