1页(5条)
equation solve problem - 消息
i want to solve below problem
m, ka, pa
i try to solve this problem
but i can't get result.
20230614_lateral earth pressure.sm (100.47 KiB)已下载 1429 次。
Thanks in advance
m, ka, pa
Thanks in advance
Hi. Maybe the attached helps, but's hard to know. At the eqn 16 I count two open [ and only one closed ].
20230614_lateral earth pressure.sm (74.8 KiB)已下载 1449 次。
WroteMy suggested solution is in the attached.
Get more accurate solutions from roots(,,,)
LateralEarthPressure.sm (13.13 KiB)已下载 1394 次。
Hi. Another way, plugin-less version. Have the advantage that can recognize the active and passive cases.
20230614_lateral earth pressure polyroots.sm (77.28 KiB)已下载 1399 次。
1页(5条)
