list calculation
list calculation - list calculation - 消息
#1 已发布: 2025/12/7 06:52:39
kimkim
kimkim
0个赞,共9个帖子。
Hi~ I'm studyng building structural analysis.
When I calculate the displacement, I have to use list calculation like below using Ti nspire.
I would try this way in smath studio, but failed.
How can I calculate in smath studio?
thank you for your help.
#2 已发布: 2025/12/7 09:23:36
StvMath
StvMath
44个赞和1个踩,共76个帖子。
The following uses vectors rather than lists:
You beat me to it by seconds!
已编辑 2025/12/7 09:24:32
kimkim 2025/12/7 14:32:35
#3 已发布: 2025/12/7 09:29:24
kimkim
kimkim
0个赞,共9个帖子。
Thank you, StvMath.
I've just found the solution, but I think your way is more efficient than mine !!
Thank you again.
已编辑 2025/12/7 09:29:46
#4 已发布: 2025/12/7 12:34:43
1,362个赞,共2,276个帖子。
I have just submitted a book on Engineering Mechanics with SMath Studio for publishing. It is to appear early next year. The examples are already available at Github https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath.
See example 5.5.
已编辑 2025/12/7 17:19:11
5位用户喜欢此帖子
sergio 2025/12/7 16:48:11, Alvaro 2025/12/8 08:52:29, Davide Carpi 2025/12/8 10:42:01, ioan92 2026/4/12 09:56:46, kimkim 2025/12/7 14:32:30
#5 已发布: 2025/12/7 16:54:33
127个赞,共342个帖子。
Martin, the link you posted mistakenly incorporates the GitHub string at the beginning, nullifying the connection; you should correct it.
#6 已发布: 2025/12/7 22:39:12
1,362个赞,共2,276个帖子。
Sergio, I can't reproduce the problem. In both instances where I posted the link, it works in my browser. Also, I see some traffic on Github today, so that I expect the link to work for others as well.
As a backup, here is the plain text link: https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath
已编辑 2025/12/7 22:41:04
sergio 2025/12/8 14:31:34
#7 已发布: 2025/12/8 09:21:48
1,558个赞,共1,868个帖子。
It was me who corrected the link.
2位用户喜欢此帖子
sergio 2025/12/8 14:31:35, Martin Kraska 2025/12/8 11:10:15
#8 已发布: 2026/4/12 07:23:00
Norrah_Casper
Norrah_Casper
0个赞,共6个帖子。
For structural analysis in SMath, using vectors usually works out much better than lists anyway, especially when you start dealing with larger matrices or displacement vectors. It keeps the math a bit cleaner and more consistent with how SMath handles calculations internally. That Engineering Mechanics book example looks like a great resource to keep on hand for these types of workflows too!
