Implicit Plot
Implicit Plot - 消息
#1 已发布: 2018/2/19 00:34:45
1,139个赞,共1,805个帖子。
Hi. I'm trying to implement this implicit plot. But can't "cut" the lines in the xy plot. Also, any help about speeding the function is welcome.
iplotq.sm (40.7 KiB)已下载 1840 次。
#2 已发布: 2018/2/19 04:35:55
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Try the method of Draghilev
DragilevMet.sm (24.09 KiB)已下载 1283 次。
#3 已发布: 2018/2/19 06:07:23
1,139个赞,共1,805个帖子。
Hi Ber. Thanks for the implementation. But it use maple and is semisymbolic, I want just some that can works in the cloud, like: https://en.smath.info/cloud/sheet/s23Pa6bZUn
#4 已发布: 2018/2/19 06:38:09
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Option without Maple
DragilevMet1.sm (21.62 KiB)已下载 1320 次。
frapuano 2018/2/19 07:15:00
#5 已发布: 2018/2/19 07:13:37
1,139个赞,共1,805个帖子。
Perfect! Thanks.
#6 已发布: 2018/2/19 19:22:41
CBG
CBG
78个赞,共312个帖子。
Not graphic
It does not show any error
#7 已发布: 2018/2/19 21:28:12
1,139个赞,共1,805个帖子。
Hi Carlos
For see the error message type B1=
#8 已发布: 2018/2/19 23:44:57
CBG
CBG
78个赞,共312个帖子。
Hello Alvaro:
Thank you very much.
The error in the graph is that x is not defined.
What causes this error?
In the graphs published by you it is seen that graphs correctly.
#9 已发布: 2018/2/22 03:11:16
1,139个赞,共1,805个帖子。
Hola Carlos. Try the following, a short version, just for n=2.
DragilevMet2.sm (12.74 KiB)已下载 1269 次。
Fridel Selitsky 2018/2/22 04:44:00
#10 已发布: 2018/2/22 04:21:24
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Try also the old version of the Draghilev method
DragilevMet3.sm (23.18 KiB)已下载 1259 次。
Razonar,thanks for the short code for n = 2
#11 已发布: 2018/2/22 14:45:42
983个赞,共6,866个帖子。
Carlos, Alvaro,
From previous use of Dragilev method, I observed great difficulties
to appropriately start/stop rkfixed. Your example above works fine as is.
For more points with less tentatives in specific cases, the easiest way
is to pass it to the closed shape Hermite suite.
I should revisit some of those examples.
The Esplina AI2000 interpolates as well for closed shapes.
Spline Esplina [AI2000].sm (21.79 KiB)已下载 1073 次。
Spline Esplina [Hermite].sm (35.44 KiB)已下载 1059 次。
Fridel Selitsky 2018/2/22 15:50:00
#12 已发布: 2018/2/22 15:55:44
CBG
CBG
78个赞,共312个帖子。
By--> Razonar
引用
By--> Ber7
引用
Try also the old version of the Dragilev method
DragilevMet3.sm (24kb) downloaded 10 time(s)
Hola Alvaro, Hello Ber7,
Thanks for your reply, but the DragilevMet2 and 3 files do not work.
The file of Ber 7 does not show any error, but by requiring the value
of B1 and B2, it says that "x" is not defined.
Attached drawing of the errors.
Hello Jean, your files worked perfectly.
#13 已发布: 2018/2/23 03:19:44
1,139个赞,共1,805个帖子。
Hola Carlos.
It's because a problem with rkfixed routine in your environment. Try to download this, or use it in the cloud: DM_RK
#14 已发布: 2018/2/23 15:56:57
CBG
CBG
78个赞,共312个帖子。
Hola Alvaro:
Gracias por tu respuesta.
Thanks for your answer, but I found the fault.
The interference is caused by the Maxima Plugin,
by disabling it, the file works correctly.
#15 已发布: 2018/2/23 23:30:39
CBG
CBG
78个赞,共312个帖子。
Hola Alvaro
Here too, the problem is caused by the decimal separator "Point",
Changing in options, the decimal separator from "Point" to "Comma", (from "." To ",")
resolves the problem of graphing
Alvaro 2018/2/24 18:48:00
