how to apply a conditional to an interval
how to apply a conditional to an interval - 消息
#1 已发布: 2022/1/5 18:03:42
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
1个赞,共27个帖子。
Good afternoon, could someone explain to me how to solve this problem I need that the horizontal voltage varies according to the depth however and the s2 gamma.
my input data is hprofundidade1 z w and y
TESTE TENSAO ADM MATRIZ.sm (5.41 KiB)已下载 1245 次。
#2 已发布: 2022/1/6 01:50:51
600个赞,共1,381个帖子。
I didn't understand what to calculate in sigma function.
A little more explanation would help to resolve it.
TESTE TENSAO ADM MATRIZ_r1.sm (8.44 KiB)已下载 1278 次。
显示剧透
#3 已发布: 2022/1/6 07:57:04
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
1个赞,共27个帖子。
I don't understand the problem, only to get a plot.
Good morning,
I reworded the file with an SPT matrix, my goal is to loop to find the value of sigma h in the depth that I inform in the input I am attaching a photo of what the final result should look like with the graph
TESTE TENSAO ADM MATRIZ.sm (13.15 KiB)已下载 1263 次。
#4 已发布: 2022/1/6 15:04:40
1,139个赞,共1,805个帖子。
Hi. I think that this could be the solution.
TESTE TENSAO ADM MATRIZ.sm (5.88 KiB)已下载 1253 次。
#5 已发布: 2022/1/6 16:49:36
600个赞,共1,381个帖子。
I still don't understand purpose of for() loops. (not in your solution, original question)
Removing for()'s and calculating directly won't change the result.
#6 已发布: 2022/1/6 19:06:33
1,139个赞,共1,805个帖子。
Hi overlord. I guess because using γ.s2(h)*h isn't correct, there the correct acumulation is γ.s2(h)*Δh
TESTE TENSAO ADM MATRIZ.sm (10.8 KiB)已下载 1227 次。
#7 已发布: 2022/1/7 08:51:39
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
1个赞,共27个帖子。
Good morning,
thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
see the resolution of the problem in the attached image
#8 已发布: 2022/1/7 11:23:15
TIAGO C DOS SANTOS
TIAGO C DOS SANTOS
1个赞,共27个帖子。
At this point, up to You to handle the project.
I understood nothing in that big image.
TESTE TENSAO ADM MATRIZ (in_situ parametric).sm (18.6 KiB)已下载 1303 次。
PERFECT FELL LIKE A GLOVE is there a way to rotate the result of the graph 90 degrees?
#9 已发布: 2022/1/7 16:01:35
1,139个赞,共1,805个帖子。
...some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
Hi. You can try to change the input values by yourself.
#10 已发布: 2022/1/7 17:44:30
1,139个赞,共1,805个帖子。
This is a way to do that in SMath.
TESTE TENSAO ADM MATRIZ v2.sm (455.7 KiB)已下载 1366 次。
#11 已发布: 2022/1/8 11:14:01
983个赞,共6,866个帖子。
... updated from Alvaro latest addition.
Cleaned image(s) for publishing the traced reference.
You can have as many sets of parameters [p,d] as you wish,
even of different length as long as you update respectively.
Cheers ... Jean.
Project Algo_Parameters.sm (661.95 KiB)已下载 1274 次。
I guess the last 4 'x' points [18,19,20,21] should be removed.
#12 已发布: 2022/1/8 14:36:52
600个赞,共1,381个帖子。
Razonar's post has answer already. Jean's post is a re-post.
No reason to re-post same file with some enigmatic, non-related, preceded functions.
TESTE TENSAO ADM MATRIZ v2.sm (455.7 KiB)已下载 1366 次。 <--- Razonar's post
Project Algo_Parameters.sm (661.95 KiB)已下载 1274 次。 <--- Jean's shameless repost (don't download this)
#13 已发布: 2022/1/8 16:45:12
983个赞,共6,866个帖子。
Offered as demanded in two separate parts in same document.
Thank you all for making your time available, helping me with this problem but some of the solutions posted here do not match the values must be equal to sigma,v in the image or 70 kN/m2 at 4m depth and 118 kN/m2 at 7m depth.
Project Algo_Parameters Copy.sm (663.42 KiB)已下载 1276 次。
#14 已发布: 2022/1/8 18:28:58
600个赞,共1,381个帖子。
I am pretty sure topic owner didn't request from someone to re-post one anothers sample.
2位用户喜欢此帖子
Alvaro 2022/1/8 20:58:00, fedeghi 2022/1/9 07:57:00
