1页(17条)
Smath Studio 98.6606 closes unexpectedly - Smath Studio quits unexpectedly when inserting a table and running the program - 消息
Smath Studio fails when a table containing arrays is inserted, and closes unexpectedly.
Test_Table.sm (6.37 KiB)已下载 1265 次。
Davide Carpi 2018/2/7 08:58:00
WroteSmath Studio fails when a table containing arrays is inserted, and closes unexpectedly.
Works with Portable 6484
Force Close with installed 6606.
It works for me too.
I note that the variables of Carlos are not in italic character.
may be this helps better to understand the situation here.
correction: force close occurs if the first element of matrix is a string.
table_test2.sm (23.06 KiB)已下载 1386 次。
Hello "ndtm", Jean, "overlord" and Sergio.
Thank you very much for your comments, recommendations, suggestions and help.
It seems that it is a Bug in Smath Studio 0.98.6606, since I tested it in the
versions of Smath Studio 0.98.6179, 98.6484 and 0.97.5346, and in
these versions it worked correctly.
I can't reproduce this issue with 6606.
Did you try updated version of Table Region?
Here is the latest deal, I have created a portable 6606 version which has no extension plugin except table region.
Now the table plugin is working as it should be. Maybe one of the installed plugins is creating the havoc.
I am going to try to find it by installing one at a time.
By---->Andrey Ivashov
Yes I Yes, I did it
Yes I Yes, I did it
Andrey Ivashov 2018/2/6 18:05:00
Andrey,
Could you please change your decimal symbol from comma to period and try to open the test file above?
I think I have found the culprit. When I change it to comma, no issues so far.
Thank you very much! I will check decimal symbol and will try to fix the plugin asap.
Issue is reproduced. Working to investigate and fix.
Please could you try to update plug-in and test your examples?
I think I have fixed the issue.
2位用户喜欢此帖子
Table region is not causing force crash.
Everything seems good, congrats.
2位用户喜欢此帖子
1页(17条)
