Smath Studio 98.6606 closes unexpectedly
Smath Studio 98.6606 closes unexpectedly - Smath Studio quits unexpectedly when inserting a table and running the program - 消息
#1 已发布: 2018/2/5 22:07:46
CBG
CBG
78个赞,共312个帖子。
Smath Studio fails when a table containing arrays is inserted, and closes unexpectedly.
Test_Table.sm (6.37 KiB)已下载 1265 次。
Davide Carpi 2018/2/7 08:58:00
#2 已发布: 2018/2/5 23:37:06
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Hello CBG!
It works for me.
#3 已发布: 2018/2/6 01:55:54
983个赞,共6,866个帖子。
Hello CBG!
It works for me.
Carlos, try this
#4 已发布: 2018/2/6 05:04:41
600个赞,共1,381个帖子。
Works with Portable 6484
Force Close with installed 6606.
#5 已发布: 2018/2/6 05:24:53
127个赞,共342个帖子。
It works for me too.
I note that the variables of Carlos are not in italic character.
#6 已发布: 2018/2/6 08:47:42
600个赞,共1,381个帖子。
may be this helps better to understand the situation here.
correction: force close occurs if the first element of matrix is a string.
table_test2.sm (23.06 KiB)已下载 1386 次。
#7 已发布: 2018/2/6 13:38:28
CBG
CBG
78个赞,共312个帖子。
Hello "ndtm", Jean, "overlord" and Sergio.
Thank you very much for your comments, recommendations, suggestions and help.
It seems that it is a Bug in Smath Studio 0.98.6606, since I tested it in the
versions of Smath Studio 0.98.6179, 98.6484 and 0.97.5346, and in
these versions it worked correctly.
#8 已发布: 2018/2/6 14:59:54
2,344个赞,共4,057个帖子。
组: Super Administrator
I can't reproduce this issue with 6606.
#9 已发布: 2018/2/6 15:24:36
2,344个赞,共4,057个帖子。
Did you try updated version of Table Region?
#10 已发布: 2018/2/6 17:14:52
600个赞,共1,381个帖子。
Here is the latest deal, I have created a portable 6606 version which has no extension plugin except table region.
Now the table plugin is working as it should be. Maybe one of the installed plugins is creating the havoc.
I am going to try to find it by installing one at a time.
#11 已发布: 2018/2/6 17:31:16
CBG
CBG
78个赞,共312个帖子。
By---->Andrey Ivashov
Yes I Yes, I did it
Andrey Ivashov 2018/2/6 18:05:00
#12 已发布: 2018/2/6 17:56:29
600个赞,共1,381个帖子。
Andrey,
Could you please change your decimal symbol from comma to period and try to open the test file above?
I think I have found the culprit. When I change it to comma, no issues so far.
#13 已发布: 2018/2/6 18:04:55
2,344个赞,共4,057个帖子。
Thank you very much! I will check decimal symbol and will try to fix the plugin asap.
#14 已发布: 2018/2/6 19:21:15
2,344个赞,共4,057个帖子。
Issue is reproduced. Working to investigate and fix.
#15 已发布: 2018/2/6 20:16:31
2,344个赞,共4,057个帖子。
Please could you try to update plug-in and test your examples?
I think I have fixed the issue.
2位用户喜欢此帖子
CBG 2018/2/6 20:42:00, Davide Carpi 2018/2/7 04:10:00
#16 已发布: 2018/2/6 20:21:20
600个赞,共1,381个帖子。
Table region is not causing force crash.
Everything seems good, congrats.
2位用户喜欢此帖子
Andrey Ivashov 2018/2/6 20:22:00, CBG 2018/2/6 20:42:00
#17 已发布: 2018/2/6 20:41:25
CBG
CBG
78个赞,共312个帖子。
Now the example works very well.
Thank you very much.
