Error Highlight not picking up the right 'error' - 消息
PileRedux_Factor_CBG.sm (115.19 KiB)已下载 1455 次。
PileRedux_Factor_CBG.pdf (376.79 KiB)已下载 816 次。
WroteThis is an approach, maybe Jean or Alvaro, can Doctor it
Hello Carlos, maybe like this ... solve(2) to let the solver breath freely.
PileRedux_Factor_CBG [1].sm (24.35 KiB)已下载 1261 次。
See attached. I've modified your strip2() algorithm [See Strip3()]. On my PC it performs same calculations ~10x faster. Might help with large data sets.
PileRedux_Factor_CBG [1]_alyles.sm (31.33 KiB)已下载 1309 次。
WroteHi Jean,
Thanks alyles ... Good job !
WroteHola Carlos. This is another approach.
Hola Alvaro.
Gracias
I make the next comment. In none of the 3 graphs that you show,
the scale of the "Y" axis, reaches the value 10, so I think,
it would be necessary to expand the scale to verify that the curves are correct
Hello Jean
Thank you so much .
Very pretty
WroteI make the next comment. In none of the 3 graphs that you show,
Carlos, the limits are the limits of the solver.
I refactored a bit to understand myself easier,
played a bit the lower limits [A5, A6] ... bingo !
That reminds me how long it toke Mathcad 11 to solve
the Solar Cell project ... let say ~ 1 month.
Page4 Carlos.sm (29.2 KiB)已下载 1650 次。
WroteHello Jean
Thank you so much. Very pretty. Best Regards. Carlos
Hola Carlos,
Few more things to improve presentation ...
Decimate part of the A1, A2,A3 . Confirm project is valid
particularly withe 'z' target in A solvers.
Project PileRedux_Factor_CBG [1].sm (30.8 KiB)已下载 1303 次。
Wrote... I make the next comment. In none of the 3 graphs that you show,
Hola Carlos. Maxima shows 10 for both axis, IPlotSolve, by construction, only can take two vectors (x or y and lambda) but not 3 (x and y and lambda).
For pIPlot and pVField, just change the Box in 'B'. I take columns only one to five.
WroteHola Carlos,
... decimated plots are lot more presentable.
At this point, for a specific target solution
easy to get a Thiele analytical formulation.
In the mean time, I will test some decay model.
Project PileRedux_Factor_CBG [1].sm (46.98 KiB)已下载 1255 次。
WroteIn the mean time, I will test some decay model.
... a pretty good fit. More models to be explored.
Project PileRedux_Factor_CBG [1] Rational Fit.sm (58.08 KiB)已下载 1297 次。
Wrote... a pretty good fit. More models to be explored.
... patience is rewarded, an exact fit
considering the inexact solver solutions.
Project PileRedux_Factor_CBG [1] Exact Homographic.sm (50.54 KiB)已下载 1286 次。
