Beta: SMath Studio 0.99.7542 (25 August 2020)
Beta: SMath Studio 0.99.7542 (25 August 2020) - 消息
#1 已发布: 2020/8/24 20:24:09
2,344个赞,共4,057个帖子。
组: Super Administrator
它提供了众多的计算功能和丰富的用户界面,并支持约40种语言。该应用程序还内置了数学参考手册。
应用程序可根据您的需求轻松扩展。内置的“扩展管理器”工具让您可以获取数百种官方及第三方资源,涵盖以下类型:使用示例、插件、基于 SMath Viewer 的应用程序、代码片段、界面翻译、交互式书籍、手册以及教程。
下载
SMathStudioDesktop.0_99_7542.Mono.tar.gz (1.4 MiB)已下载 2893 次。
SMathStudioDesktop.0_99_7542.Setup.msi (2.27 MiB)已下载 6375 次。
10位用户喜欢此帖子
Вячеслав Мезенцев 2020/8/25 01:18:00, sergio 2020/8/25 04:55:00, Denis Nikitin 2020/8/25 06:41:00, IVR 2020/8/25 09:16:00, NDTM Amarasekera 2020/8/25 11:51:00, Arie 2020/8/25 12:38:00, frapuano 2020/8/26 03:32:00, Serg 2020/8/26 11:34:00, Davide Carpi 2020/8/28 14:36:00, Василий Николаевич Храмушин 2020/9/20 09:58:00
#2 已发布: 2020/8/25 06:26:19
1,139个赞,共1,805个帖子。
Hi. Thanks! Very much!
"equrep() function supports variables/functions replacements now."
Any example about what that means?
Also, I see that this error persists:
#3 已发布: 2020/8/25 18:07:08
2,344个赞,共4,057个帖子。
Hello Alvaro!
Yes, this is a main reason why I can't release stable version of SMath Studio now. I'm working on this issue right now.
Alvaro 2020/8/25 20:27:00
#4 已发布: 2020/8/27 17:11:26
983个赞,共6,866个帖子。
Any example about what that means ?
Can you show an application of it ?
An image is good enough.
Thanks ... Jean
#5 已发布: 2020/8/27 21:24:31
1,139个赞,共1,805个帖子。
Thanks ... Jean
Hi Jean. Here: Applications for equrep: expression isolation and laplace transform.
2位用户喜欢此帖子
IVR 2020/8/29 12:29:00, frapuano 2020/8/28 02:53:00
#6 已发布: 2020/8/29 06:54:30
2,344个赞,共4,057个帖子。
Thanks ... Jean
Just to make it clear: equrep() function is not something I'm spending time on to create/support/improve. This function appeared as a demo of the updated symbolic core of SMath Studio. This function is an interface to the new functionality. You can use it or not, but it demonstrates possibilities of the symbolic simplifications SMath Studio provides.
Unfortunately it has at least one issue which is hard to fix. I'm doing my best to remove a bug, but if it will be too hard maybe I will revert my changes and use stable (which is used in latest stable version of the application) symbolic core again.
So it is not about equrep() function it is about core of the program, its performance, possibilities, behaviors etc. If you are remember, all the calculations in SMath Studio goes through symbolic optimization, so it is pretty important.
4位用户喜欢此帖子
sergio 2020/8/29 12:58:00, Serg 2020/8/30 09:20:00, IVR 2020/8/29 12:29:00, frapuano 2020/8/29 12:34:00
#7 已发布: 2020/8/30 12:12:30
983个赞,共6,866个帖子。
Thanks Alvaro ... always there in Smath Community !
BTW Andrey, if/else, if/otherwise have not been observed
detrimental in timing in general applications.
For this application [Julia], timing kills Smath ... Oh !
OK, my Win 7 1.66 GHz is steam engine.
What about your latest Beta SS 7542 ?
Thanks ... Jean
Pattern Julia Set [PUBLISH].sm (172.79 KiB)已下载 1671 次。
#8 已发布: 2020/8/30 16:33:41
600个赞,共1,381个帖子。
Maybe it is a bug maybe intended I don't know;
On 7542 for underlined text regions, spaces are not underlined.
No problem for letters, numbers, punctuations, etc.
Writer regions don't have this issue.
#9 已发布: 2020/9/9 12:12:34
1,362个赞,共2,276个帖子。
I can't switch on/off any more the border of image regions (and also fo Maxima draw regions) in 7542.
In 7251 this still works. It also works for documents produced in 7542.
#10 已发布: 2020/9/9 19:32:12
2,344个赞,共4,057个帖子。
Thank you! Fixed.
#11 已发布: 2020/9/9 19:33:22
2,344个赞,共4,057个帖子。
I can't reproduce this issue locally. Please could you upload a files (one with correct behavior and another with incorrect)?
#12 已发布: 2020/9/10 07:16:24
1,362个赞,共2,276个帖子。
I attach two files. The first one is created in 7542. No matter what I do in the contex menu, the border can't be switched off. Neither is there a change in the GUI, nor is the xml attribute changed.
If I load this file in 7251, then I can switch off the border, this is both visible on the canvas and in the xml entry.
Once I save that (second file), this can be opened by 7542 and the change is respected. And you guess it, the border can't be switched on again. Thus, actually there is no wrong file, just wrong GUI behaviour.
7542 displays existing files correctly. Just no access to this one setting.
I leave out the maxima draw region, as this might prevent reproduction without maxima installation.
border 7542.sm (7.87 KiB)已下载 1972 次。
border 7542 then 7251.sm (7.87 KiB)已下载 1934 次。
Andrey Ivashov 2020/9/13 07:33:00
#13 已发布: 2020/9/13 07:35:16
2,344个赞,共4,057个帖子。
Thank you very much. Fixed now.
There is one issue with the plug-in: invalidation of the region is not requested after menu item usage (it must be done by plug-in) so borders will be visually switched only after region redrawn, f.e. after scrolling or focus in/out.
Martin Kraska 2020/9/13 18:42:00
#14 已发布: 2020/9/13 16:55:14
2,344个赞,共4,057个帖子。
Issue is fixed in the latest stable version I have just published. equrep() made less powerful, so it will leave an equation as is in cases where error is possible. Like your example.
This is temporary solution but it is required to continue development without serious stoppers. In future I will continue working to make symbolic engine more smart.
Alvaro 2020/9/13 17:11:00
#15 已发布: 2020/9/13 19:00:12
1,362个赞,共2,276个帖子。
This also seems to be the cause for delayed re-draw after editing operation (you have to get focus off the image to see the changes). Very valuable hint!
Filed in the bug tracking system as SS-4640
#16 已发布: 2020/9/16 18:43:50
1,139个赞,共1,805个帖子。
I post that question because interpret that then equrep works replacing f by sin in this example: "equrep(3+f(x),f,sin)=3+f(x)" but now I see that the correct way is "equrep(3+f(x),f(a),sin(a))=3+sin(x)"
Here my attempt to convert an expression with operators to an expression with binary or unary functions only
_to_expr.sm (51.03 KiB)已下载 1990 次。
_to_expr.pdf (223.76 KiB)已下载 1174 次。
#17 已发布: 2021/10/30 20:11:38
1,139个赞,共1,805个帖子。
Rematch ... It's seems to work now.
num2expr.sm (39.06 KiB)已下载 1870 次。
num2expr.pdf (176.65 KiB)已下载 1337 次。
sergio 2021/10/31 12:37:00
