Lagrange Multipliers
Lagrange Multipliers - Lagrange Multipliers - Messages
#1 Posted: 2018/10/22 16:52:10
Draghilev is on the menu ... is it applicable in there ?
Maths Lagrange Multipliers Copy.sm (59.81 KiB) downloaded 1026 time(s).
#2 Posted: 2018/10/23 08:05:41
1,106 likes in 1,784 posts.
Hi Jean. Yes, it is ... but just give only one point, because there are only one solution. And the method requires at least one starting point ...
Drag_Jean.pdf (54.46 KiB) downloaded 594 time(s).
Drag_Jean.sm (49 KiB) downloaded 1044 time(s).
#3 Posted: 2018/10/23 18:06:21
Maximization added.
Drag_Jean max and min.pdf (76.37 KiB) downloaded 578 time(s).
Drag_Jean max and min.sm (56.51 KiB) downloaded 961 time(s).
#4 Posted: 2018/10/23 23:18:35
Maximization added.
Thanks Alvaro ... gorgeous solutions.
The Draghilev part persists "Syntax incorrect".
Don't worry Alvaro: You are doing so much for Smath Community !!!
Maths Lagrange Multipliers Alvaro [Maximize-Minimze] Copy.sm (23.64 KiB) downloaded 909 time(s).
