Definite integral - "x - not defined" ?
Definite integral - "x - not defined" ? - 消息
#1 已发布: 2019/2/7 10:08:26
Conrad
Conrad
0个赞,共1个帖子。
I have the following problem, trying to solve the definite integral int((3*x^3-x^2+2*x-4)/sqrt(x^2-3*x+2),dx,0,1): I get the error "x - not defined" and, of course, no result.
If I change the limits to [0..401], I get a result (!) with no error message, but if I set the upper limit lower than 401, I get the error again...
What is the reason for that?
Thanks in advance for your replies.
Conrad
#2 已发布: 2019/2/7 11:13:06
983个赞,共6,866个帖子。
The integrand is undefined @ x = 1
#3 已发布: 2019/2/7 11:41:17
983个赞,共6,866个帖子。
Three verdicts in there:
1. Nothing will integrate that freak above x=1.9999999999999999999999999999
2. Nothing will integrate up to x=0.99999999999999999999999999999999
3. Can only integrate in reasonable range of the integrand.
Interesting Classroom example ... always plot the integrand !!!
IntegrateFreak.sm (7.28 KiB)已下载 1247 次。
#4 已发布: 2019/2/7 12:32:46
983个赞,共6,866个帖子。
Hello Conrad,
Often, it is possible to improve the Smath native Simpson integrator.
Romberg is profitable in example 2 which looks easy from plotting
the integrand, but finally is not so.
Integrate Romberg Technical.sm (51.89 KiB)已下载 1243 次。
#5 已发布: 2019/2/8 03:50:36
600个赞,共1,381个帖子。
you can use maxima plugin if it is necessary.
#6 已发布: 2019/2/8 06:33:47
1,139个赞,共1,805个帖子。
Hi. I think that here the point is how to handle avoidable discontinuities in SMath. Because integral and other operators or functions not accept the 'if' statement, you can use 'cases' in the definition of f, as this:
Even this isn't the case, this other is more general for avoiding numerical issues with avoidable discontinuities:
sergio 2019/2/8 08:59:00
#7 已发布: 2019/2/8 06:47:42
1,139个赞,共1,805个帖子。
About the other discontinuity, at x=2, I guess that you don't want to work with complexes. It's usual take the absolute vale of logs and roots in real analysis calculus. This other isn't avoidable discont, but can be handled in a similar way.
discont_integral.sm (8.65 KiB)已下载 1232 次。
3位用户喜欢此帖子
Вячеслав Мезенцев 2019/2/8 08:30:00, frapuano 2019/2/8 09:52:00, NDTM Amarasekera 2019/2/8 12:14:00
#8 已发布: 2019/2/8 08:33:05
1,558个赞,共1,868个帖子。
maple() also can do that.
未找到文件。 未找到文件。
2位用户喜欢此帖子
frapuano 2019/2/8 09:53:00, NDTM Amarasekera 2019/2/8 12:14:00
#9 已发布: 2019/2/8 13:34:33
983个赞,共6,866个帖子。
maple [0..1] = -2.98126694400594
Mathcad 11 [0..1]= -2.98126694400554
Smath = -2.98126668567898 ... acc 10000
This is a case of singular end point
#10 已发布: 2019/2/8 15:16:38
1,139个赞,共1,805个帖子。
... This other isn't avoidable discont, but can be handled in a similar way.
Well, actually, the integral converges for x=2, as one can see in this wolfram result
That's means that numerical procedure for computing int in SMath needs some improvements.
#11 已发布: 2019/2/8 16:13:59
983个赞,共6,866个帖子。
That's an old long due request.
At least, we have the adaptive from Carlos
Romberg algo style works well, very useful too.
