Function from plot
Function from plot - 消息
#1 已发布: 2023/6/6 08:19:33
Valery Ochkov
Valery Ochkov
67个赞,共716个帖子。
How can I get a function from this plot?
#2 已发布: 2023/6/6 08:59:59
983个赞,共6,866个帖子。
How can I get a function from this plot ?
1. Probably from the expensive digitizer suggested by Richard [Mathsoft Collaboratory]
2. Piecewise from Tracer.
3. Try Mathsoft digitizer.
4. Smath difficult
At this point from the collected data set, fit a model function.
Cheers ... Jean.
Valery Ochkov 2023/6/6 10:24:00
#3 已发布: 2023/6/6 10:05:20
Brian Runagle
Brian Runagle
13个赞,共27个帖子。
Does this help?
Graphing.pdf (164.86 KiB)已下载 1557 次。
Brian
#4 已发布: 2023/6/6 10:15:02
⚜ Kenny Lemens, P.E. ᵂᴵ
85个赞,共181个帖子。
Greetings,
How can I get a function from this plot? 🖼
That is a straight line on a semi-log graph; you can reference this handout: https://inside.mines.edu/~epoeter/_GW/LAB/EquationsOfStraightLinesOnDifferentTypesGraphPaper.pdf
Per this handout, your equation should be
y = b + m*log(x)
where:
  • m = difference in y over one log cycle of x
  • b = y value corresponding to x=1
May this be of Good Help;
#5 已发布: 2023/6/6 12:44:34
1,139个赞,共1,805个帖子。
Hi. You can try this post Approximation of a functional curve in a digital image or this other one: Embedding images into a plot
2位用户喜欢此帖子
Вячеслав Мезенцев 2023/6/6 14:16:00, Valery Ochkov 2023/6/6 13:45:00
#6 已发布: 2023/6/6 14:19:52
983个赞,共6,866个帖子。
Hello Valery,
some Smath digitizing utilities
Cheers, Jean.
Digitize Tracer 15.sm (28.83 KiB)已下载 1404 次。
Digitize OVNI Copy.sm (69.15 KiB)已下载 1387 次。
Digitize Contour Isocurve Himmelblau Copy.sm (106.67 KiB)已下载 1445 次。
Digitize Curve.sm (295.86 KiB)已下载 1378 次。
Digitize Contour.sm (829.05 KiB)已下载 1461 次。
Digitize Clean_Strip_Smooth.sm (1.76 MiB)已下载 1498 次。
#7 已发布: 2023/6/6 15:29:30
983个赞,共6,866个帖子。
... this Himmelblau has resident Gray matrix.
Digitize Contour Isocurve Himmelblau Copy.sm (107.19 KiB)已下载 1449 次。
Valery Ochkov 2023/6/7 01:02:00
#8 已发布: 2023/6/6 17:11:16
1,139个赞,共1,805个帖子。
Hi. Hope this helps.
Modeling a functional curve in a digital image.pdf (860.39 KiB)已下载 929 次。
Modeling a functional curve in a digital image.sm (1 MiB)已下载 1510 次。
3位用户喜欢此帖子
Valery Ochkov 2023/6/7 01:02:00, sergio 2023/6/7 06:34:00, darlbeck 2023/6/7 14:59:00
