Angles trygonometry value in solutions of the system of equations
Angles trygonometry value in solutions of the system of equations - 消息
#1 已发布: 2021/9/9 04:25:42
Mateusz
Mateusz
0个赞,共8个帖子。
How to turn of the decimal values in trygonometry angles value? I got sth lik this for solution of system of equations:
The file with example: example_v1.sm (8 KiB)已下载 1201 次。
A.
#2 已发布: 2021/9/9 06:44:19
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
You can use the function al_nlegsolve with any initial
assumptions (because the equations are linear)
al_nlegsolve.sm (11.18 KiB)已下载 1200 次。
#3 已发布: 2021/9/9 09:52:40
983个赞,共6,866个帖子。
How to turn of the decimal values in trigonometry angles value ?
By default, trig are in decimal radian in all CAS.
Recast your solutions, fill-in the unit place holder.
#4 已发布: 2021/9/9 23:20:45
1,139个赞,共1,805个帖子。
Hi. You also can use Maxima commands, in this case ev():
#5 已发布: 2021/9/10 05:37:18
1,362个赞,共2,276个帖子。
example_v1.sm (13.63 KiB)已下载 1214 次。
sergio 2021/9/10 06:11:00
#6 已发布: 2021/9/10 13:02:39
1,139个赞,共1,805个帖子。
Hi Martin. I use Maxima's ev() because SMath's Assign() only works with the variable names, instead others, like xo, yo, and SMath's at() doesn't works for the symbolic evaluation, as shown this picture:
example_v1.sm (15.95 KiB)已下载 1193 次。
This is a workaround for use only SMath native functions or plugins, without any explicit Maxima function:
example_v2.sm (15.16 KiB)已下载 1262 次。
sergio 2021/9/10 13:43:00
