format results polar in degrees
format results polar in degrees - How to show matrix results in polar format in degrees - 消息
#1 已发布: 2025/10/12 18:46:36
Russ Patterson
Russ Patterson
0个赞,共5个帖子。
I am one tiny step away from freeing myself of Mathcad Prime. I just need to know how to format the result of a matrix/vector operation so it is in polar form with angle in degrees. The attached image is a snip from a Mathcad result. How is this possible in SMath?
best regards,
russ
#2 已发布: 2025/10/13 06:58:46
fominantokha
fominantokha
0个赞,共3个帖子。
See
https://smath.com/en-US/forum/topic/kAz5NZ/How-to-do-polar-form-like-mathcad_
已编辑 2025/10/13 06:59:51
#3 已发布: 2025/10/13 13:40:26
Russ Patterson
Russ Patterson
0个赞,共5个帖子。
Thank you. That does not address formatting a vector result in polar with degrees (what I'm after) as best I can tell. I want to display my resulting vector in polar with degrees.
Also, I tested the "pol" function and it assumes the angle is in radians.
Worksheet1.sm (10.64 KiB)已下载 1132 次。
#4 已发布: 2025/10/14 09:09:21
1,139个赞,共1,805个帖子。
Hi. You can try something like this, using the table plugin.
showPolarForm.sm (18.3 KiB)已下载 1179 次。
Russ Patterson 2025/10/14 18:01:09
#5 已发布: 2025/10/14 18:04:28
Russ Patterson
Russ Patterson
0个赞,共5个帖子。
Thank you. That works rather well.
1) Is there a way to hide that showPF function at top of my worksheet?
2) I can't figure out how to make it report a very tiny imaginary component as zero. See bottom of attached. showPolarForm.sm (20.74 KiB)已下载 1199 次。
best regards,
russ
p.s. It would also be great if we could control the table borders at an individual column level - so I can make it look like brackets around the results.
#6 已发布: 2025/10/14 18:27:56
127个赞,共342个帖子。
1) Menu --> Insert --> Area. Place the functions you want to hide between the two lines. Then click the little square with the – sign to collapse the area."
Russ Patterson 2025/10/14 20:42:47
#7 已发布: 2025/10/14 22:59:16
1,139个赞,共1,805个帖子。
Hi. Modified version.
showPolarForm.sm (21.93 KiB)已下载 1220 次。
2位用户喜欢此帖子
sergio 2025/10/15 17:42:32, Russ Patterson 2025/10/15 20:51:43
#8 已发布: 2025/10/15 20:51:58
Russ Patterson
Russ Patterson
0个赞,共5个帖子。
Outstanding! thank you
