While loop never ends
While loop never ends - 消息
#1 已发布: 2020/3/13 15:27:06
Yes Man
Yes Man
0个赞,共6个帖子。
Hi everyone, I've got problem with while loop. I have this function with Xstart = 0.2 ; Xfinish = 2 ; deltaX = 0.2 and I need to solve it in smath studio, but while loop is processing forever and never ends. I'm doing something wrong, or it's a bug? Thanks!
Images:
https://postimg.cc/Q9mqWkKd Smath studio
https://postimg.cc/KKZkgXPt Function I need to solve
#2 已发布: 2020/3/13 16:58:44
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Is this what you need?
#3 已发布: 2020/3/13 17:14:41
Yes Man
Yes Man
0个赞,共6个帖子。
No, I need a range of numbers for X and Y, like: First X = 0.2, it's calculating Y(0.2) and shows first Y result, then X = 0.4 (previous X + delta X) and it's calculating Y(0.4), and until x = 2. In final I need a range of all X and all Y results.
#4 已发布: 2020/3/13 17:30:47
983个赞,共6,866个帖子。
Some examples ...
Utilities Pts Critical Monte-Carlo.sm (18.33 KiB)已下载 1253 次。
Utilities Program While FindIndex.sm (34.87 KiB)已下载 1238 次。
#5 已发布: 2020/3/13 17:55:24
Yes Man
Yes Man
0个赞,共6个帖子。
Some examples ...
I'm not sure I understood how to solve my function by this examples.
I don't know what I'm doing wrong:
#6 已发布: 2020/3/13 20:38:39
983个赞,共6,866个帖子。
Your proposal is not a case of while loop,
strictly wrong application.
Page44 Unknown.sm (73.22 KiB)已下载 1468 次。
#7 已发布: 2020/3/14 06:06:47
1,362个赞,共2,276个帖子。
You can do the job using a while loop but it is just one option (perhaps not the most straightforward one).
loops.sm (10 KiB)已下载 1267 次。
3位用户喜欢此帖子
Davide Carpi 2020/3/14 07:20:00, frapuano 2020/3/14 08:38:00, sergio 2020/3/14 14:01:00
#8 已发布: 2020/3/14 06:19:48
Yes Man
Yes Man
0个赞,共6个帖子。
I need all X and all Y(x) values in the end, for Xfirst = 0.2, Xlast = 2 with step 0.2.
y(0.2)=
y(0.4)=
y(0.6)=
y(2)=
And it should look something like this:
x= 0.2 y= -0.6126
x= 0.4 y= 0.2173
x= 0.6 y= 0.7064
x= 0.8 y= 1.0721
x= 1.0 y= 1.3842
x= 1.2 y= 1.6771
x= 1.4 y= 1.9738
x= 1.6 y= 2.2924
x= 1.8 y= 2.6501
x= 2.0 y= 3.0639
I can type every y(x) in smath studio:
https://postimg.cc/0bddLTqF
But, is it possible to do it with while loop?
#9 已发布: 2020/3/14 06:21:13
Yes Man
Yes Man
0个赞,共6个帖子。
y(0.2)=
y(0.4)=
y(0.6)=
y(2)=
x= 0.2 y= -0.6126
x= 0.4 y= 0.2173
x= 0.6 y= 0.7064
x= 0.8 y= 1.0721
x= 1.0 y= 1.3842
x= 1.2 y= 1.6771
x= 1.4 y= 1.9738
x= 1.6 y= 2.2924
x= 1.8 y= 2.6501
x= 2.0 y= 3.0639
#10 已发布: 2020/3/14 08:25:47
983个赞,共6,866个帖子。
What you are asking for is so restricted and useless for purpose !
Then you can:
1. start wherever [L] as long as computable your ln(,)
2. end wherever [N]
3. as fine step size [Δ]
4. algo style for infinite applications
#11 已发布: 2020/3/14 08:52:29
Yes Man
Yes Man
0个赞,共6个帖子。
Then you can:
2. end wherever [N]
I'm asking for this cos' we are learning Pascal programming language in university, and we need to write this function in Pascal with [while a<=b do], and check it in MathCAD or SMath studio program.
I don't need any graphics, I just need to check the function with while loop. You sent example without while loop and without Xlast = 2, so is it possible to check this function with while loop, or no?
#12 已发布: 2020/3/14 10:11:42
983个赞,共6,866个帖子。
Pascal is pretty retarded these days for Engineering applications !
Years ago, Mathcad for Universities was pretty freaked.
Better use Smath productive for studies & Engineering.
Golden ratio will be a life time productive Companion.
As well as an advanced WhileLoop.
Golden Ratio jmG.sm (39.41 KiB)已下载 1232 次。
#13 已发布: 2020/3/14 11:20:50
1,443个赞,共2,936个帖子。
Absolutely, and there are several ways.
If you need a step-by step feedback on the fly you can use breakpoints (menu of math regions) and the debugger window ("View" menu). You might have to store the intermediate results in a dedicated variable though, to don't look into the whole matrix at each step.
Also you can use the function trace() and the output window, or you can build math strings using concat() and other functions, or maybe something more complex using the script region plugin by uni.
loops-1.sm (30.01 KiB)已下载 1174 次。
3位用户喜欢此帖子
sergio 2020/3/14 14:35:00, frapuano 2020/3/14 16:00:00, SteelCat 2020/5/17 15:51:00
