solving simultaneous equations with Solve
solving simultaneous equations with Solve - Solve() Maxima not working - 消息
#1 已发布: 2022/4/5 15:45:27
Mo
Mo
0个赞,共34个帖子。
hi,
I used the Solve function a lot before but for some reason it does not work for this simple example.
I need to get the RayLeigh Damping factors alpha and beta using two frequencies, so two simple simultaneous equations should do it. tried using Solve but no luck.
Does anyone know why it is not solving?
Thanks in advance
未找到文件。未找到文件。
#2 已发布: 2022/4/5 16:39:40
127个赞,共342个帖子。
显示剧透
test_sergio.sm (8.05 KiB)已下载 1265 次。
Mo 2022/4/5 22:22:00
#3 已发布: 2022/4/5 18:24:50
600个赞,共1,381个帖子。
You can use roots() for your function. And a vectorize() can simplify it.
However, to use Assign() you will need this function to merge vars and solutions.
Assign_without_Maxima Solve().sm (7.36 KiB)已下载 1334 次。
#4 已发布: 2022/4/5 22:22:48
Mo
Mo
0个赞,共34个帖子。
Thanks Overlord, PompelmoTell, greatly appreciated!!
#5 已发布: 2022/4/6 10:28:07
⚜ Kenny Lemens, P.E. ᵂᴵ
85个赞,共181个帖子。
Greetings,
Another approach would be to use some elbow grease, you can substitute terms by hand and solve for 𝛼 and 𝛽:
Keypress (You can copy/paste the following into your worksheet):
α:{2*D*ω.1*ω.2}/{ω.1+ω.2}
β:α/{ω.1*ω.2}
*NOTE: ω.1 and ω.2 shown above are variables with subscript, they are not vectors ω[1 and ω[2; You should be able to substitute ω.1 for ω[1 if that serves your purposes.
- Kenny Lemens, P.E.
Mo 2022/4/6 11:57:00
#6 已发布: 2022/4/6 11:40:36
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
If the damping coefficients are denoted by α1 and α2, you can use the function al_nlegsoive
test.sm (6.99 KiB)已下载 1351 次。
2位用户喜欢此帖子
sergio 2022/4/6 12:26:00, Mo 2022/4/6 11:57:00
#7 已发布: 2022/4/7 11:08:53
983个赞,共6,866个帖子。
Fridel Selitsky 2022/4/7 11:54:00
#8 已发布: 2022/4/7 13:43:03
983个赞,共6,866个帖子。
... more in there from native Smath code.
Solve FindRoot FORUM.sm (10.9 KiB)已下载 1330 次。
#9 已发布: 2022/4/7 17:27:55
600个赞,共1,381个帖子。
solving with uni's latest addition mathcad blocks;
you wouldn't need Eq: actually, but it can be shown.
mathblock.sm (5.15 KiB)已下载 1330 次。
Mo 2022/4/9 22:28:00
#10 已发布: 2022/4/7 18:19:34
600个赞,共1,381个帖子。
I think this is the most sophisticated method of my way.
It can get unknowns from equation, solve them.
In the end assigns numerical values to unknowns.
You don't need to define alpha or beta or any variable.
All process is automatic.
mathblock_v2.sm (5.19 KiB)已下载 1341 次。
There is also this way for guess define.
#11 已发布: 2022/4/8 02:19:42
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
This is good, but for a system of linear equations(our case), the guess can be arbitrary.
#12 已发布: 2022/4/8 20:04:07
1,362个赞,共2,276个帖子。
And finally a version with Solve() and list injection region:
mathblock_Solve.sm (4.86 KiB)已下载 1298 次。
sergio 2022/4/9 04:48:00
#13 已发布: 2022/4/11 09:57:44
85个赞,共181个帖子。
Greetings,
If plugins are considered, you can also consider the use of Maple:
In the image I posted, the 'equal sign' shown on those two equations are actually symbolic equals; keypress: [ctrl] + [.] instead of keypress [=].
Kenny Lemens, P.E.
#14 已发布: 2022/4/11 16:44:08
1,139个赞,共1,805个帖子。
Hi. The isol solution, using only the Mathcad block plugin.
isol_example.sm (68.13 KiB)已下载 1279 次。
isol_example.pdf (34.57 KiB)已下载 741 次。
sergio 2022/4/12 05:01:00
#15 已发布: 2022/4/14 12:10:17
Mo
Mo
0个赞,共34个帖子。
Thank you all for the feedback, is there a literature or manual to explain the Mathcad block plugin?
Thanks
#16 已发布: 2022/4/14 14:54:00
983个赞,共6,866个帖子。
Thank you all for the feedback, is there a literature or manual to explain the Mathcad block plugin ?
For that particular example, maple is an algebraic export.
Mathcad block has not yet been exemplified in Smath Community
of what it can do vs what native Smath can't.
Cheers ... Jean.
Codes Solve.sm (12.46 KiB)已下载 1321 次。
#17 已发布: 2022/4/14 19:43:45
983个赞,共6,866个帖子。
Exercise the Mathcad bloc
#18 已发布: 2022/4/14 20:19:07
600个赞,共1,381个帖子。
Thanks
We have what Viacheslav provided us.
There are some samples or functions too which individual users uploaded.
You can look the extension page for some examples.
And there are some samples in forum topic that users posted.
It may be a small bunch, but we try to understand its capabilities.
This feature/plugin is also new to us.
https://en.smath.com/forum/yaf_postst726_Mathcad-Toolbox.aspx
