Text Region Utilities
Text Region Utilities - Helps to set some Text Region properties - 消息
#41 已发布: 2022/11/3 20:54:35
983个赞,共6,866个帖子。
I can get links to files to work in Writer region, but being able to auto generate would be great. I can't quite figure it out.
auto generate ... you mean click on an ordinary text region
to convert in Writer Region and open the WR ribbon.
There is one more option you may need from Settings.
... the Wrap option(s) custom/page.
Custom delivers the stretch RHS handle.
Superb for inserting math region(s) in the WR.
In few clicks, you can offer an abstract publishing style.
No matter the size/color of an ordinary text region,
paste in WR ... default Arial ... then Settings.
Cheers ... Jean.
#42 已发布: 2022/11/4 05:37:22
1,443个赞,共2,936个帖子。
Is this plugin expected to work with 8253?
I'll check it, thank you.
#43 已发布: 2022/11/4 10:28:37
983个赞,共6,866个帖子。
That's what I meant ... 3 clicks:
1 ► WR ... 2 ► Settings [Ribbon] ... 3 ► Wrap Custom [RHS Handle]
#44 已发布: 2022/11/4 11:13:39
600个赞,共1,381个帖子。
That is absolutely not what he meant.
2位用户喜欢此帖子
Mark R Harris 2022/11/5 17:29:00, Oscar Campo 2022/11/4 13:47:00
#45 已发布: 2025/10/22 13:18:07
Денис
Денис
0个赞,共1个帖子。
adding a new link to a worksheet doesn`t work (neither a new text), following message is issued:
What could be a reason?
#46 已发布: 2025/10/23 11:14:17
1,443个赞,共2,936个帖子。
SMath API has changed and I wasn't able to find a way to restore this feature.
已编辑 2025/10/23 12:00:30
