Wrong display of output units
Wrong display of output units - 消息
#1 已发布: 2020/10/18 17:44:45
EngMath
EngMath
0个赞,共51个帖子。
I've just started using this software and I think that it's great. However, I came across an issue that may be a bug. Here's my input:
a := 0,1 m
b := 0,05 m
L := 1 m
M := 1000 Nm
τ_max := (2*M)/(π*a*(b^2)) =
Now in the last line I want to change units to MPa. But when I do it (by writing MPa in the right placeholder), I get the following result:
No matter what I try, I can't get rid of this part that I highlighted in red. I want to have just MPa on the right side. Is that a bug or am I doing something wrong ?
#2 已发布: 2020/10/18 17:54:25
600个赞,共1,381个帖子。
Nothing is wrong.
Could you please check your expressions carefully?
#3 已发布: 2020/10/18 17:59:32
1,443个赞,共2,936个帖子。
Perhaps you are using 'Nm instead of 'N*'m
If you want you can define your own torque unit 'Nm:'N*'m before the calculations, otherwise you have to multiply the force unit fot the length unit
EngMath 2021/5/30 09:05:00
#4 已发布: 2020/10/18 18:02:47
EngMath
EngMath
0个赞,共51个帖子。
Problem solved, thank you very much. I had to type 'N*'m as you say because 'Nm wasn't recognized properly.
#5 已发布: 2020/11/10 08:35:58
Int16
Int16
0个赞,共9个帖子。
How to compute this
#6 已发布: 2020/11/10 12:20:49
127个赞,共342个帖子。
The problem is due to the internal storage of the program in Kelvin. You find several threads in the forum. you can also find an explanation in Martin Kraska's interactive guide (Tools menu -> Options -> Plugins -> interactive books). However the solution is to use DeltaC °
Davide Carpi 2020/11/12 10:10:00
#7 已发布: 2020/11/12 09:04:06
Int16
Int16
0个赞,共9个帖子。
Thanks a lot.
#8 已发布: 2020/11/12 10:30:53
983个赞,共6,866个帖子。
... you can make the unit system silent, i.e: inactive
#9 已发布: 2020/11/13 17:55:49
1,362个赞,共2,276个帖子。
This is close to recommending pencil and paper.
#10 已发布: 2020/11/14 08:49:14
983个赞,共6,866个帖子。
Pretty close Martin, that's ± what QA sanity check does.
The mV/I temperature converter reads mV ... then displays °C.
In parallel to the black box mV/I, read mV, interpolate wrt NBS [now NIST].
#11 已发布: 2020/11/14 14:24:48
983个赞,共6,866个帖子。
wrong display of output units
You will have infinitely many of those, easy to doctor:
1. make the system silent, though not quite paper/pencil
2. make it user style at will.
