1页(19条)
plot a function - 消息
Hello everyone!
I have difficulty plotting the function c which depends on the derivatives of two functions which in turn depend on the parameter t.
Could anyone help me? This in the smath file.. curvatura.sm (11.36 KiB)已下载 1656 次。
Thank you so much
Thank you so much
WroteHello everyone!
I have difficulty plotting the function c which depends on the derivatives of two functions which in turn depend on the parameter t...
Maybe this is what you want...
... and the .sm file: curvatura1.sm (9.4 KiB)已下载 1696 次。
WroteCould anyone help me ?
To plot both systems ... Jean
curvatura.sm (11.63 KiB)已下载 1807 次。
Maths Tangent.sm (91.95 KiB)已下载 1701 次。
thank you very much for your help, I hope I have no more problems
Wrotethank you very much for your help, I hope I have no more problems
You´re welcome.
It's okay to ask, because you express the need to know. It is better to ask than keep silence
Thank you very much for the availability.
But I need more help.
How can I draw the tangent line to the equation in parametric form?
this is the file … curvatura2.sm (12.5 KiB)已下载 1739 次。
Hi Ale. Here, some ways.
curvatura3.sm (25.1 KiB)已下载 1696 次。
curvatura4.sm (20.83 KiB)已下载 1690 次。
sergio 2019/12/6 17:23:00
WroteThank you very much for the availability.
For the Tangent over C(t), it will follow the scalar rules
of the document Tangent.sm posted before.
The Tangent over the parabola is another business.
Smath does not derive linterp(x) as it is NOT a function
only an interpolation. This project and lot more are
rescued via Infinitesimal Analysis [dates back before CAS].
For that particular typical user point of tangency, OK.
You may want to experiment more .
Don't mind to see noisy curvature [disabled in collapsed].
Chers ... Jean.
curvatura2 Copy.sm (30.56 KiB)已下载 1676 次。
Thanks for the answers.
But if I wanted to find the tangent to the curve when the parameter t changes, how should I do?
WroteThanks for the answers.
Do you mean the envelope, all the tangents for the range en T?
curvatura5 - envelope.sm (23.64 KiB)已下载 1573 次。
Best regars.
sergio 2019/12/6 17:19:00
WroteHi Ale. Here, some ways.
Thanks Alvaro ... superb/saved ... Jean
Your project has been refactored strictly on discrete.
OK, you have functions but life is from collected data.
Collected data are always noisy from the quantization,
a small amount of Gaussian Ksmooth is often sufficient.
Ksmooth being applied before cinterp
As exemplified, cinterp is the best interpolator for
a clean curvature plot from infinitesimal maths.
I don't understand what your were attempting c(t) last module.
Please, don't hesitate for more.
Maths Tangent Data Set Copy.sm (36.61 KiB)已下载 1656 次。
sergio 2019/12/7 07:36:00
WroteYour project has been refactored strictly on discrete.
O
.... more maths are coming:
cumulative integration, arc length
derivative you already have it from last attachment.
Thank you very much for the help, I appreciate it very much.
I hope to be able to continue alone.
kind regards
kind regards
WroteThank you very much for the help, I appreciate it very much.
kind regards
Your project now all done, based on discrete collected data,
collected data that you will have to smooth [not offered].
Smoothing is a large Engineering tool box !
Let's see the continued adventure.
Maths Tangent Data Set.sm (60.84 KiB)已下载 1648 次。
sergio 2019/12/7 11:50:00
Hello Alvaro, Is graphing a tangent line as exhibited in "curature3.sm" only available for a plot/function in parametric form, i.e. is this available for a cartesian plot/function?
I welcome your review and look forward to your reply.
Sincerely,
Norm
Sincerely,
Norm
Hi Norm. You can parametrize f(x) as {x(t)=t, y(t)=f(t)} and substitute in the formulas x'(t)=1, x''(t)=0, x(t) -> x and y(t) -> y(x).
curvatura3 - Cartesian.sm (40.25 KiB)已下载 1706 次。
sergio 2024/9/21 18:01:00
Thanks Alvaro! As always, great examples to work with!
Sincerely,
Norm
Sincerely,
Norm
1页(19条)
