1页(4条)
API - function name with subscript - 消息
Hi!
My next question about Smath API is about function names. Is there any possibility to create function with subscript in its name?
Below I present some code which contains definition of function. I want to obtain function like: greek epsilon. Can it be done?
public static TermInfo GetTermInfo()
return new TermInfo(
"ε.c3",
TermType.Function,
"ec3 value of concrete class.",
FunctionSections.Unknown,
true,
new ArgumentInfo(ArgumentSections.Variable, true)
Thank you again - now I see that it can be done but your answer results in two more questions:
1) How are you including C# code in Smath region? Is it just print screen or real code in some type of region which is evaluating on fly? Looks like magic for me (in MathCAD it is impossible to do such things).
2) You are using Definition and Store classes. During searching in example plugins I found that there are used mainly in customizable controls. I am developing some sort of functions by implementing IPluginHandleEvaluation interface.
How to combine your solution (Store and Definition) with TermInfo[]?
public TermInfo[] TermsHandled
get
return this.termInfos;
public void Initialize()
this.assemblyInfos = new[]
new AssemblyInfo("SMath Studio", new Version(0, 98), new Guid("a37cba83-b69c-4c71-9992-55ff666763bd"
this.termInfos = new[]
Fck.GetTermInfo(),
Fck_cube.GetTermInfo()
//Example GetTermInfo function
"Fck",
TermType.Function,
"Fck value of concrete class.",
true,
引用1) How are you including C# code in Smath region? Is it just print screen or real code in some type of region which is evaluating on fly? Looks like magic for me (in MathCAD it is impossible to do such things).
Yes, the code is executed on the fly. This is just a Script region.
引用2) You are using Definition and Store classes. During searching in example plugins I found that there are used mainly in customizable controls. I am developing some sort of functions by implementing IPluginHandleEvaluation interface.
This is features of Script region. In your case, you have to write it differently. I just showed that this will work.
1页(4条)
