Unable to open sm file
Unable to open sm file - 消息
#1 已发布: 2021/2/26 13:52:59
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
While making finishing touches to the attached SM file (latest version), a warning message
propped up to continue or quit. I continued, saved and closed.
But now unable to open it. It loads but immediately closes without any message.
Can this be recovered please?
This is the first time I came across this type of an issue.
I use latest WIN 10 64 bit Home edition
TEST.sm (387.7 KiB)已下载 1677 次。
#2 已发布: 2021/2/26 14:22:14
600个赞,共1,381个帖子。
For information, same behavior with bug under Linux.
Seems a line break is written wrong to file.
Corrected it with text editor and tried to save under smath to replicate the bug.
Couldn't achieve to bug reappear again.
Code was like this previously.
<p><br>EE</br>Calculate the head losses and the corrected fows in the various pipes of a </p>
Revised to this with text editor.
<p>EE<br />Calculate the head losses and the corrected fows in the various pipes of a</p>
TEST_rcv.sm (488.99 KiB)已下载 1706 次。
#3 已发布: 2021/2/26 14:41:00
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Corrected it and tried to save to replicate the bug.
Thank you very much for your contribution.
It saved me a lot of trouble.
#4 已发布: 2021/2/26 21:01:16
600个赞,共1,381个帖子。
You are welcome, happy to help you.
#5 已发布: 2021/2/27 12:18:02
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
I've had this issue before. Thanks for the fix, the last time this happened, I had a backup. The funny thing is, per HTML code, the first screenshot looks "more" correct.
NDTM, I spotted what appears to be minor spelling error. FLOWS, not FOWS
#6 已发布: 2021/2/27 12:30:47
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Yes. Thank you. Now I made the correction.
#7 已发布: 2021/3/1 01:31:58
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Whenever I try to edit contents of some description boxes the unhandled exception error message props up. For information of Developers please.
#8 已发布: 2021/3/1 07:41:53
1,443个赞,共2,936个帖子。
Please attache the content of the "Details" window.
IDK I'm only an amateur HTML coder but to me
always has been a void/empty element; looking at standards:
In the orginal HTML (up to 4.01) only
is correct;
In XHTML
and
are allowed,
is not allowed.
In HTML 5 only
and
are allowed,
is not allowed.
something
was newer allowed, so it seems an encoding bug to me.
#9 已发布: 2021/3/1 12:25:09
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Details Window.txt (30.14 KiB)已下载 1292 次。
Pipe_Network_EX_HARDY_CROSS.sm (299.12 KiB)已下载 1580 次。
#10 已发布: 2021/3/4 08:53:47
2,344个赞,共4,057个帖子。
组: Super Administrator
Both issues fixed. Thank you!
#11 已发布: 2021/3/5 13:45:27
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Thank you Andrey!
#12 已发布: 2021/3/25 10:21:12
JenniferCastillo
JenniferCastillo
0个赞,共4个帖子。
Most accurate and informative answer.
