ODE2 - Not a proper differential equation?
ODE2 - Not a proper differential equation? - 消息
#1 已发布: 2024/10/7 15:12:57
Cornel
Cornel
2个赞,共78个帖子。
Why is saying that its not a proper differential equation?
#2 已发布: 2024/10/7 17:20:54
StvMath
StvMath
44个赞和1个踩,共76个帖子。
#3 已发布: 2024/10/7 17:56:58
Cornel
Cornel
2个赞,共78个帖子。
And then if someone wants to solve a > 2 order differential equation (3th order, 4th order, etc), how to do it? What algorithm, command should I use/rely in SMath Studio?
#4 已发布: 2024/10/7 18:18:13
1,558个赞,共1,868个帖子。
#5 已发布: 2024/10/7 18:57:17
Cornel
Cornel
2个赞,共78个帖子。
And there are also some approach using maxima engine/command?
#6 已发布: 2024/10/8 15:11:16
1,362个赞,共2,276个帖子。
Sure. Here is one using Maxima's desolve function and one using ODE.2 (without solving for the integration constants)
RLC.sm (23.17 KiB)已下载 1694 次。
Feder-Masse.sm (23.13 KiB)已下载 1699 次。
#7 已发布: 2024/10/9 14:42:41
Cornel
Cornel
2个赞,共78个帖子。
Martin, do you have an example for a third order differential equation on how to solve it? because ode2 is limited to second order differentia eq as far as I understood. And my previous question was on how to sollve a differential eq of order > 2 (3, 4, etc)?
#8 已发布: 2024/10/9 18:47:10
1,362个赞,共2,276个帖子。
Here I cirumvent the limitations of the translation using multiple intervals of integration. Example from the interactive handbook.
Worksheet36.sm (40.73 KiB)已下载 2392 次。
