Tangent/Normal
Tangent/Normal - Tangent/Normal - 消息
#1 已发布: 2017/9/15 10:17:00
983个赞,共6,866个帖子。
Maths Tangent.sm (24.15 KiB)已下载 1357 次。
2位用户喜欢此帖子
Davide Carpi 2017/10/6 04:53:00, Andrey Ivashov 2017/9/15 10:51:00
#2 已发布: 2017/9/15 12:28:29
алексей
алексей
17个赞,共78个帖子。
From Maple.
One face of the cube belongs to the tangent plane to the surface at each point of the curve.
http://www.mapleprimes.com/posts/208425-Tangent-Plane-As-The-Square-At-Any-Point-Of-A-Smooth-Surface-#comment202577
#3 已发布: 2017/9/15 16:42:49
983个赞,共6,866个帖子。
Superb application ! ... Thanks
#4 已发布: 2017/10/6 03:19:23
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
The tangent to the curve and the normal to the surface
The curve is given as the intersection line of two surfaces f1 and f2.
It can be seen that the normal to the sphere passes through its center.
Normal'4.sm (52.09 KiB)已下载 1361 次。
2位用户喜欢此帖子
Davide Carpi 2017/10/6 04:53:00, Oscar Campo 2017/10/6 21:30:00
#5 已发布: 2017/10/6 11:04:20
983个赞,共6,866个帖子。
Thanks for that one, added in dedicated file.
BTW, thanks for your latest meshed Torus, nice.
I was wondering if you can animate two more:
1. Add a point on Analemma wrapped on the sphere, animate the point ?
2. Animate [slide] the Advection on the graph ? Very nice in Mathcad !
Cheers, Thanks in advance: Jean
Solve Tridiagonal [ADVECTION].sm (56.63 KiB)已下载 1117 次。
Analemma.sm (139.1 KiB)已下载 1318 次。
#6 已发布: 2017/10/6 16:24:24
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Flat animation we have already done:
https://en.smath.info/forum/resource.ashx?a=14479&b=2
One of the variants on the sphere.Unfortunately, the graph looks flat.
Analemma Anim.sm (31.07 KiB)已下载 1334 次。
Davide Carpi 2017/10/10 11:51:00
#7 已发布: 2017/10/6 23:28:48
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Fixed bug
Analemma Anim1.sm (36.26 KiB)已下载 1328 次。
#8 已发布: 2017/10/9 17:39:33
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
The tangential plane and the normal to the surface
Normal'5.sm (79.91 KiB)已下载 1304 次。
#9 已发布: 2017/10/10 04:19:26
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Normal'8.sm (55.02 KiB)已下载 1369 次。Adding
Normal'7.sm (54.56 KiB)已下载 1351 次。
#10 已发布: 2018/4/10 05:15:08
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Tangent, normal and binormal vectors
Curves can be specified parametrically, algebraically or by a coordinate matrix
Spiral2.sm (36.43 KiB)已下载 1263 次。
Sinus.sm (48.77 KiB)已下载 1346 次。
VivianiSph.sm (37.41 KiB)已下载 1273 次。
VivianiTor.sm (52.14 KiB)已下载 1352 次。
Davide Carpi 2018/4/11 19:16:00
#11 已发布: 2018/4/10 08:20:38
983个赞,共6,866个帖子。
Thanks Ber7, saved.
#12 已发布: 2018/4/11 16:13:04
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Lorenz attractor
Lorenc.sm (36.26 KiB)已下载 1297 次。
2位用户喜欢此帖子
Davide Carpi 2018/4/11 19:16:00, NDTM Amarasekera 2018/4/11 23:05:00
#13 已发布: 2018/4/12 11:12:12
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Roessler Attractor
Rossler Attractor.sm (36.68 KiB)已下载 1345 次。
