Factor polynomials?
Factor polynomials? - 消息
#1 已发布: 2014/10/9 02:41:33
vnaumov
vnaumov
0个赞,共2个帖子。
Does SMath support factoring polynomials, like:
2x + 6
=> 2(x + 3)
#2 已发布: 2014/10/10 11:00:44
Gerry_Bush
Gerry_Bush
12个赞,共14个帖子。
Hello vnaumov,
I have tried your example using symbolic evaluation and SMath gives the result:
2.x + 6 = 2.(3 + x)
Is this what you need?
vnaumov 2014/10/11 03:58:00
#3 已发布: 2014/10/10 13:40:49
1,558个赞,共1,868个帖子。
You can use Maple or Maxima for this purpose.
#4 已发布: 2014/10/11 03:52:38
vnaumov
vnaumov
0个赞,共2个帖子。
Thank you, Maxima does factoring, like x^2 + 4*x + 4 ==> (x + 2)^2
I downloaded "Unofficial portable distribution with Maxima", https://smath.com/wiki/%28S%28p1gq0245uny440554qdivzik%29%29/SMath%20with%20Plugins.ashx
