SHOW EQUATION, NOT RESULT
SHOW EQUATION, NOT RESULT - 消息
#1 已发布: 2020/9/22 08:37:20
LeandroMartins
LeandroMartins
1个赞,共9个帖子。
Hello everyone.
I have an If shown in the image below. I would like that in addition to the result of the equation, it would also be shown from which equation the result originated.
It is possible?
#2 已发布: 2020/9/22 09:37:22
983个赞,共6,866个帖子。
It is possible?
Maybe ... but document is missing ... Ah !
#3 已发布: 2020/9/22 10:14:47
127个赞,共342个帖子。
Leandro, for example like this:
Leandro.sm (7.13 KiB)已下载 1223 次。
As Jean says help us get help and always attach the smath file with the problematic example.
#4 已发布: 2020/9/22 11:37:05
LeandroMartins
LeandroMartins
1个赞,共9个帖子。
Thank´s so much Sergio. It´s Works very nice.
Next time I will put smath file.
Attach the math file only to check my solution. But this is in Portuguese!
Memoria de Calculo Monovia.sm (243.67 KiB)已下载 1186 次。
#5 已发布: 2020/9/22 17:41:26
1,139个赞,共1,805个帖子。
Hi. Those are very similar to the Sergio (Pompelmo Tell) solution:
#6 已发布: 2020/9/23 09:31:24
983个赞,共6,866个帖子。
Often, if/otherwise is more convenient in program.
In some applications, program accepts only if/else.
Generally < is incompletely determined ... ≤ is completely determined.
It may result in an error message or simply an error w/o message.
if-else ... if-otherwise.sm (21.1 KiB)已下载 1189 次。
