Double Integration using ode solvers
Double Integration using ode solvers - 消息
#1 已发布: 2020/6/4 01:40:08
1,139个赞,共1,805个帖子。
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions.
DoubleIntegralRK.sm (42.67 KiB)已下载 1458 次。
DoubleIntegralRK.pdf (219.12 KiB)已下载 1029 次。
2位用户喜欢此帖子
frapuano 2020/6/4 04:03:00, sergio 2020/6/4 04:42:00
#2 已发布: 2020/6/7 13:21:46
SteelCat
SteelCat
3个赞,共47个帖子。
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition?
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman)
#3 已发布: 2020/6/7 19:50:25
983个赞,共6,866个帖子。
Can the change of variable be put in the procedure definition,?
Like this: yes, just opposite plot.
Double Switch [x, L].sm (6.33 KiB)已下载 1176 次。
#4 已发布: 2020/6/17 20:21:22
1,139个赞,共1,805个帖子。
Hi. This is the double integral using Gauss Legendre quadrature.
GaussLegendreQuadrature.sm (60.58 KiB)已下载 1455 次。
GaussLegendreQuadrature.pdf (160.77 KiB)已下载 1041 次。
Yes.
DoubleIntegralSteelCat.sm (47.08 KiB)已下载 1429 次。
DoubleIntegralSteelCat.pdf (105.49 KiB)已下载 850 次。
2位用户喜欢此帖子
sergio 2020/6/18 05:14:00, frapuano 2020/6/18 07:33:00
#5 已发布: 2020/6/18 11:26:19
983个赞,共6,866个帖子。
Keisan has longer Legendre than 64, but couldn't copy/paste ?
From other source: 63, 64.
Integrate Legendre [ Wr 24 ].sm (28.98 KiB)已下载 1211 次。
#6 已发布: 2020/6/18 21:35:42
1,139个赞,共1,805个帖子。
Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath.
In the attached Laguerre and Legendre coeffs for the Gauss method.
DoubleIntegralJean.sm (25.63 KiB)已下载 1391 次。
DoubleIntegralJean.pdf (45.11 KiB)已下载 951 次。
2位用户喜欢此帖子
sergio 2020/6/19 05:41:00, frapuano 2020/6/19 09:34:00
#7 已发布: 2020/6/20 07:39:28
983个赞,共6,866个帖子。
Thanks, Amigo !
