How to calculate the effective value of segmented voltage waveform
How to calculate the effective value of segmented voltage waveform - There is the voltage waveform but segmented, tried to calculate the effective value but failed. - 消息
#1 已发布: 2025/12/9 15:16:47
liwenbus
liwenbus
0个赞,共7个帖子。
Dear Friends,
I tried to calculate the effective value of segmented voltage waveform, but failed, could you help me to fixed it? Thank you very mucn! RMS calc.sm (10.21 KiB)已下载 992 次。 image.png
#2 已发布: 2025/12/9 18:38:59
1,139个赞,共1,805个帖子。
Hi. This is a way. You can see also the file RMS in this post.
Also:
RMS-example.sm (17.81 KiB)已下载 920 次。
已编辑 2025/12/9 18:46:12
#3 已发布: 2025/12/10 21:55:31
1,362个赞,共2,276个帖子。
Version without killing the units:
RMS-example.sm (8.29 KiB)已下载 925 次。
In the original version, just making the periodicity function unit-proof, is sufficient:
2位用户喜欢此帖子
Alvaro 2025/12/11 00:34:52, liwenbus 2025/12/11 12:51:24
#4 已发布: 2025/12/11 12:50:32
liwenbus
liwenbus
0个赞,共7个帖子。
OH! I see! Thank you Alvaro!
Wen.
Also:
#5 已发布: 2025/12/11 12:53:13
liwenbus
liwenbus
0个赞,共7个帖子。
It helps a lot, thank you very much!
wen.
