1 Pages (5 items)
How to calculate the effective value of segmented voltage waveform - There is the voltage waveform but segmented, tried to calculate the effective value but failed. - Messages
Dear Friends,
I tried to calculate the effective value of segmented voltage waveform, but failed, could you help me to fixed it? Thank you very mucn! RMS calc.sm (10.21 KiB) downloaded 596 time(s).
Hi. This is a way. You can see also the file RMS in this post.
Also:
RMS-example.sm (17.81 KiB) downloaded 527 time(s).
Also:
Edited 2025/12/9 18:46:12
Version without killing the units:
RMS-example.sm (8.29 KiB) downloaded 519 time(s).
In the original version, just making the periodicity function unit-proof, is sufficient:
OH! I see! Thank you Alvaro!
Wen.
Wen.
WroteHi. This is a way. You can see also the file RMS in this post.
Also:
It helps a lot, thank you very much!
wen.
wen.
WroteVersion without killing the units:
1 Pages (5 items)
