Conversion between Cartesian coordinates and Geodetic coordinates
Conversion between Cartesian coordinates and Geodetic coordinates - 消息
#1 已发布: 2021/8/31 04:54:17
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
often found in geodesy and astronomy, for example, when
determination of location by GPS.
Converting geodetic coordinates to Cartesian coordinates is not difficult.
Converting Cartesian coordinates to geodetic coordinates is more difficult
because. the transformation formulas include the projection of a point onto
the surface of the Earth's ellipsoid.
In this program, the calculation of the orthogonal projection is borrowed
from the program
https://en.smath.com/forum/yaf_postsm69369_Draghilev-method-revisited.aspx#post69369
statya revolution.sm (74.77 KiB)已下载 1208 次。
revolution.pdf (349.09 KiB)已下载 861 次。
#2 已发布: 2021/8/31 08:28:23
Fridel Selitsky
Fridel Selitsky
520个赞,共451个帖子。
Converters of direct and inverse transformation of coordinates
Geod to Cart.sm (44.9 KiB)已下载 1228 次。
Cortesian_to_Geodetic.sm (50.69 KiB)已下载 1255 次。
Alvaro 2021/8/31 09:47:00
