plot function
plot function - The derivative of a function does not appear - 消息
#1 已发布: 2019/12/10 10:32:25
Ale16595
Ale16595
0个赞,共35个帖子。
Hello everybody.
I can't understand why the phi function does not compare in the graph.
This function is the derivative of the phi function that instead appears in the graph.
Someone could help me please?
Thanks in advance
this is the file… Derivate.sm (22.19 KiB)已下载 1188 次。
#2 已发布: 2019/12/10 12:31:00
983个赞,共6,866个帖子。
1. your φ(t) plots correct
2. The Smath derivative operator works on derivative rules.
3. The φ(t) is too much a monkey business for derivative rules.
4. Rescue via transit infinitesimal analysis.
5. Your constrain in plot argument is obsolete since if/otherwise
was introduced by Davide from f(x) menu "cases".
Derivate (1 doctored).sm (24.69 KiB)已下载 1199 次。
#3 已发布: 2019/12/10 14:36:26
Ale16595
Ale16595
0个赞,共35个帖子。
Thanks for the reply, I solved this problem.
Now, however, an error appears that does not make me draw a graph.
the error says: "The result is higher than the maximum positive value allowed"
what does it mean?
curvatura.sm (48.33 KiB)已下载 1219 次。
#4 已发布: 2019/12/10 17:30:44
983个赞,共6,866个帖子。
what does it mean?
... doctored version works top2bottom
1. Remember λ(x) as used
2. More problem(s) ... return the doctored version.
3. Delete all the black
curvatura (1 doctored).sm (53.54 KiB)已下载 1209 次。
#5 已发布: 2019/12/10 18:39:51
1,139个赞,共1,805个帖子。
what does it mean?
Hi. Means that' you have divide by zero or something other invalid operation. You must to avoid that for plots with restrictions in the ranges, or with try ... on error in a routine for range plots. Attached have this second option.
curvatura - moto v2.sm (43.4 KiB)已下载 1145 次。
curvatura - moto v2.pdf (371.21 KiB)已下载 876 次。
sergio 2019/12/11 06:03:00
#6 已发布: 2019/12/11 01:38:57
1,139个赞,共1,805个帖子。
This technique enable the view of symbolics.
curvatura - moto v3.pdf (460.93 KiB)已下载 852 次。
curvatura - moto v3.sm (1.12 MiB)已下载 1221 次。
