CoolProp units
CoolProp units - Getting 'strange' units and can't override them - 消息
#1 已发布: 2017/8/1 07:43:27
Peter J Francis
Peter J Francis
0个赞,共18个帖子。
Hi all ,
I'm putting together a sheet using the CoolProp wrapper
It generally works really well except for the following
Where I'm getting strange units for the Specific Heat capacity of Air
I've tried overriding the units but still don't get what I want (J/kg/K)
I've attached an extract from the sheet --> UnitsProblem.sm (7.04 KiB)已下载 1397 次。
Probably a really simple answer but I can't seem to find it !!
Peter J Francis Twitter: @PeterJFrancis Thermal Engineer , Maker , Pilot
#2 已发布: 2017/8/1 09:37:11
1,362个赞,共2,276个帖子。
Can't reproduce. J/(kg*K) works. Paste 'J/{'kg*'K} to the square placeholder to the right of the unit when the region has focus.
Peter J Francis 2017/8/2 05:18:00
#3 已发布: 2017/8/1 17:05:37
983个赞,共6,866个帖子。
Can't reproduce either "Units don't match",
because there is NO heat capacity unit in Smath.
#4 已发布: 2017/8/1 18:52:12
CBG
CBG
78个赞,共312个帖子。
You just have to change the units.
#5 已发布: 2017/8/2 05:28:04
Peter J Francis
Peter J Francis
0个赞,共18个帖子。
Thanks All,
You are all correct (I knew the answer was going to be obvious ) , pasting in the units J/kg K works fine
Its just that Gy/K seems an odd default unit
Thanks for your help
Peter
#6 已发布: 2017/12/4 16:09:32
usamakhan
usamakhan
7个赞,共98个帖子。
hey fellows, how do I calculate WET steam properties through this extension,lets suppose at 16Bar Pressure & 0.7 quality 7 which IFP standard is currently being used?
#7 已发布: 2017/12/5 10:27:10
983个赞,共6,866个帖子。
how do I calculate WET steam properties through this extension,lets suppose at [b]16Bar Pressure
Good question. The vapor phase is dry and properties don't change.
That portion of water that drags at the bottom of piping must be
taken into account for massflow calculation.
At the speed steam flows, better be dry. If not => will destroy
my control valves. Puzzling question ?
#8 已发布: 2017/12/5 11:17:30
usamakhan
usamakhan
7个赞,共98个帖子。
The property(s) that does change when you add water to steam is NOT its pressure or temperature but its enthalpy ...the most major parameter which defines the amount of work that can be extracted
Yes wet steam at very high velocities can be micro bullets for control valves & turbine blades causing erosion
#9 已发布: 2017/12/5 12:00:21
983个赞,共6,866个帖子。
Worst than erosion => cavitation.
Can't help more. Steam out of the balloon is dry, isn't ?
If you have wet steam out of the balloon, you have a serious level control problem.
