Beta: SMath Studio 0.99.6858 (11 October 2018) - Messages
Download
SMathStudioDesktop.0_99_6858.Mono.tar.gz (1.34 MiB) downloaded 2021 time(s).
SMathStudioDesktop.0_99_6858.Setup.msi (2.21 MiB) downloaded 4636 time(s).
By the way I noticed the linux and windows versions have layout difference.
Same file opened in SMath (6853) via "Arch Linux" an "Windows 10" has misaligned regions.
Regions under Linux are wider and pictures regions are bigger I guess.
I use cups-pdf to preview under Linux if it will help and I just noticed I can't print to pdf. But I can preview it.
Regards.
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continiously updated when file is opened or reloaded?
Thanks!
WroteThank you for great formatting updates!
Thanks!
In the meantime, You could manually achieve this by right-clicking date field and choosing "disable evaluation" after the file is created the first time. Re-enable, reevaluate sheet, then disable anytime you recopy file or want to update the field. .
WroteMay I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continuously updated when file is opened or reloaded?
Interesting request, but between the moment a work sheet is first created
and the last saving [dozen and dozen times saved], the first time saved
has no more meaning: is it ?
Windows timestamp [hover on sheet name] is the last saved.
Print preview page header is the actual time
"Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt".
Should I try to reinstall version 0.99.6839 - Stable (released at 2018-09-22) - recommended?
Thanks for the help in advance.
Mustafa
WroteHi,
I know the limitations for importing Mathcad files. I have used it in the last couple of months without much trouble to partially import old mathcad sheets.
But, i get this error with the latest version: "Object reference not set to an instance of an object."
Thanks!
Thank you for the report. Issue is fixed now. Fix will be available into the next beta release.
Best regards!
