Beta: SMath Studio 0.99.6858 (11 October 2018)
Beta: SMath Studio 0.99.6858 (11 October 2018) - 消息
#1 已发布: 2018/10/10 19:54:46
2,344个赞,共4,057个帖子。
组: Super Administrator
它提供了众多的计算功能和丰富的用户界面,并支持约40种语言。该应用程序还内置了数学参考手册。
应用程序可根据您的需求轻松扩展。内置的“扩展管理器”工具让您可以获取数百种官方及第三方资源,涵盖以下类型:使用示例、插件、基于 SMath Viewer 的应用程序、代码片段、界面翻译、交互式书籍、手册以及教程。
下载
SMathStudioDesktop.0_99_6858.Mono.tar.gz (1.34 MiB)已下载 2717 次。
SMathStudioDesktop.0_99_6858.Setup.msi (2.21 MiB)已下载 5682 次。
9位用户喜欢此帖子
Вячеслав Мезенцев 2018/10/11 04:24:00, Davide Carpi 2018/10/11 04:25:00, frapuano 2018/10/11 05:10:00, NDTM Amarasekera 2018/10/11 05:10:00, sergio 2018/10/11 05:15:00, Arie 2018/10/11 08:35:00, overlord 2018/10/12 12:46:00, Denis Nikitin 2018/10/16 02:24:00, Serg 2018/10/18 03:10:00
#2 已发布: 2018/10/12 13:38:12
600个赞,共1,381个帖子。
New header-footer option is awesome. This will help me to reduce file sizes a lot.
By the way I noticed the linux and windows versions have layout difference.
Same file opened in SMath (6853) via "Arch Linux" an "Windows 10" has misaligned regions.
Regions under Linux are wider and pictures regions are bigger I guess.
I use cups-pdf to preview under Linux if it will help and I just noticed I can't print to pdf. But I can preview it.
Regards.
#3 已发布: 2018/10/14 06:28:42
ianlh
ianlh
0个赞,共38个帖子。
On this latest version (mono), when selecting the units, the box only fills with the first. when required to use a different unit you can move down, but nothing is shown apart from the help/hint box.The Linux version i am using is Mint 18.3.
未找到文件。未找到文件。
#4 已发布: 2018/10/15 16:01:30
1,362个赞,共2,276个帖子。
There is no "Field" entry in the Text_Eng.lang file (for Insert> Field).
#5 已发布: 2018/10/17 14:42:38
Alexander O. Melnik
Alexander O. Melnik
127个赞,共498个帖子。
Thank you for great formatting updates!
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continiously updated when file is opened or reloaded?
Thanks!
#6 已发布: 2018/10/17 18:14:08
Arie
Arie
94个赞,共285个帖子。
Thanks!
In the meantime, You could manually achieve this by right-clicking date field and choosing "disable evaluation" after the file is created the first time. Re-enable, reevaluate sheet, then disable anytime you recopy file or want to update the field. .
sergio 2018/10/18 04:55:00
#7 已发布: 2018/10/18 18:00:08
983个赞,共6,866个帖子。
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continuously updated when file is opened or reloaded?
Interesting request, but between the moment a work sheet is first created
and the last saving [dozen and dozen times saved], the first time saved
has no more meaning: is it ?
Windows timestamp [hover on sheet name] is the last saved.
Print preview page header is the actual time
#8 已发布: 2018/10/19 12:46:24
Farja
Farja
1个赞,共7个帖子。
I know the limitations for importing Mathcad files. I have used it in the last couple of months without much trouble to partially import old mathcad sheets.
But, i get this error with the latest version: "Object reference not set to an instance of an object."
Thanks!
#9 已发布: 2018/10/21 09:06:25
Kizilcay
Kizilcay
0个赞,共4个帖子。
I observed the same error with the same Smath Studio version on Windows 8.1 (German). The message appears in German:
"Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt".
Should I try to reinstall version 0.99.6839 - Stable (released at 2018-09-22) - recommended?
Thanks for the help in advance.
Mustafa
#10 已发布: 2018/10/21 09:15:00
Kizilcay
Kizilcay
0个赞,共4个帖子。
Just an update to the above error message. I uninstalled the latest beta version and installed the last stable version 0.99.6839. The problem was solved. I can open/import Mathcad files (.xmcd).
#11 已发布: 2018/10/26 14:55:58
2,344个赞,共4,057个帖子。
Thanks!
Thank you for the report. Issue is fixed now. Fix will be available into the next beta release.
Best regards!
