Table Region Problem
Table Region Problem - Wrong display of a matrix - 消息
#1 已发布: 2023/8/27 05:58:19
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Hello !
I have this display problem when trying to pass
a matrix to a Table.
Table_Region_Problem.sm (11.47 KiB)已下载 1591 次。
#2 已发布: 2023/8/27 09:11:12
600个赞,共1,381个帖子。
Unit summary doesn't work as it should either.
Maybe these are bugs. Regards
NDTM Amarasekera 2023/8/27 10:09:00
#3 已发布: 2023/8/27 15:07:33
NDTM Amarasekera
NDTM Amarasekera
130个赞,共352个帖子。
Hello !
My post #1 is a simple example to show the Table Region problem.
The actual problem is related to a Slope Stability Analysis example,
where the result consist of the following.
1. Strip width
2. Relevant Min Factor of Safety (Min_FS)
3. Center cordinates (x,y) of slip circle relevant to Min_FS
4. Corresponding Radius of slip circle.
#4 已发布: 2023/8/28 04:31:21
1,362个赞,共2,276个帖子。
In the attached sheet I tried to automatically compile a results summary. Note that there is a single entry point for unit specification in the algorithm (no chance for mismatch between displayed unit and unit used to calculate the numerical values.
1-3.sm (137.75 KiB)已下载 1580 次。
#5 已发布: 2023/8/28 07:53:00
983个赞,共6,866个帖子。
At post #3 construct the matrix as independent cols, thus compatible Table.
Next, nest the two pertinent cols to explicit your Engineering c/w header.
#6 已发布: 2024/1/4 21:52:24
Leonardo Cocco
Leonardo Cocco
0个赞,共2个帖子。
When I downloaded the latest version of Smath Studio, the Table region Plugin does not updated correctly. As a consequence the files containing tables developed with the plugin do not open correctly. Is there any solution in the future for this issue?. Best regards,
Leonardo.
#7 已发布: 2024/1/4 22:04:34
983个赞,共6,866个帖子。
Leonardo.
Smath Solver 30405 is OK for my Tables.
#8 已发布: 2024/1/5 01:10:03
1,443个赞,共2,936个帖子。
Leonardo.
New program versions might require to update code of some plugins. The release time it depends on how many plugins are affected and how many changes are required (also the Release Manager seems still not completely restored).
#9 已发布: 2024/1/5 18:10:22
1,443个赞,共2,936个帖子。
Plugin released, thanks to Andrey for updating the code.
#10 已发布: 2024/1/8 19:32:17
Leonardo Cocco
Leonardo Cocco
0个赞,共2个帖子。
Thanks for your replies, they were of help.
