Findstr function
Findstr function - 消息
#1 已发布: 2014/2/17 08:22:59
127个赞,共342个帖子。
It seems that the "findstr" function gives a numeric value of type special format.
For this reason the Boolean operations on the result would not work properly .
[albumimg]345[/albumimg]
#2 已发布: 2014/2/17 08:30:39
1,443个赞,共2,936个帖子。
Hi Sergio,
Is not a bug of findstr, this returns a list of matches or -1 (but boolean's lacks are already known)
You need to change the logic of your script (see the attachment)
Best regards,
Davide
#3 已发布: 2014/2/17 11:11:40
127个赞,共342个帖子。
Thanks for the explanation Davide,
as you have pointed out, the Boolean implementation needs to be improved.
Your trick has worked well.
