SMath论坛 SMath Studio Questions How to apply initial conditions in second-order differential equations 1页(3条) How to apply initial conditions in second-order differential equations - How to apply initial conditions in second-order differential equations - 消息 转到最后一个帖子 #1 已发布: 2025/12/7 03:59:55 kimkim 0个赞,共9个帖子。 组: User How to apply initial conditions in second-order differential equationsThe solution to the second-order differential equation has been obtained as follows.If we want to find the solution by applying the initial conditions y(t)=0, y'(t)=0,what should I do in the following steps?thank you for your help. 已编辑 2025/12/7 06:53:24 #2 已发布: 2025/12/7 09:07:00 StvMath 44个赞和1个踩,共76个帖子。 组: User Once you've got y(t) you could simply do the following: 1位用户喜欢此帖子kimkim 2025/12/7 21:41:13 #3 已发布: 2025/12/7 12:54:45 Martin Kraska 1,362个赞,共2,276个帖子。 组: Moderator If you don't need the function v(t), you can specify the initial conditions directly: (example 10.2 in https://github.com/sn-code-inside/Technische-Mechanik-mit-SMath) Technische Mechanik mit SMath Studio: https://link.springer.com/book/10.1007/978-3-658-50592-9 3位用户喜欢此帖子sergio 2025/12/7 17:07:45, kimkim 2025/12/7 21:41:18, ioan92 2025/12/9 10:52:27 1页(3条) 有新帖 无新帖
