wrong mixed second derivateves
wrong mixed second derivateves - omorr - 消息
#1 已发布: 2012/6/25 04:17:37
325个赞和1个踩,共2,052个帖子。
Look at this please
[MATH=eng]f:el(x,1)^3+el(x,2)^3[/MATH]
This is correct:
[MATH=eng]diff(diff(f,el(x,1)),el(x,2))=0[/MATH]
But this is obviously wrong:
v0.95
[MATH=eng]diff(diff(f,el(x,2)),el(x,1))=-el(x,2)*(-1+el(x,2))[/MATH]
It seems that is still present in v.90 as well:
v0.90
[MATH=eng]diff(diff(f,el(x,2)),el(x,1))—-(-1+el(x,2))*el(x,2)[/MATH]
In v0.89.8 you will get the right answer - zeros for both mixed derivatives.
#2 已发布: 2012/7/30 03:14:57
This is still present in 0.95 build 4594 (30 July 2012).
Any comments?
#3 已发布: 2012/7/30 18:59:59
1,443个赞,共2,936个帖子。
Hi omorr,
Any comments?
I confirm!
seem related to the symbolic simplification (see the attachments)
regards,
w3b5urf3r
derivatives_debug.sm (36.92 KiB)已下载 1393 次。
Radovan Omorjan 2012/7/31 01:55:00
#4 已发布: 2012/10/8 19:26:09
1,443个赞,共2,936个帖子。
Here some (probably) related issues.
best regards,
w3b5urf3r
#5 已发布: 2012/10/10 16:33:54
Ruben Sidranski
Ruben Sidranski
17个赞,共465个帖子。
It's the way SMath handles/prioritizes ASCII characters. I ran into a similar issue with MathCAD. In this case, the second variable of "x" (in the equation) has to be the first variable of the first derivative as shown in w3b5urf3r's screen shot.
#6 已发布: 2013/5/3 16:11:41
I must be boring with this , but I think there is neither solution nor satisfactory explanation of this "glitch" regarding second derivatives.
Still present in 0.96
#7 已发布: 2013/5/3 16:23:02
1,558个赞,共1,868个帖子。
#8 已发布: 2013/5/3 16:32:12
Yes, I know. Thank you . I did it on purpose, just to put the stress that maple did it right.
