i can't match units.
i can't match units. - 消息
#1 已发布: 2023/3/7 00:02:39
soomoon
soomoon
1个赞,共42个帖子。
how can i do?
thank you
未找到文件。未找到文件。
#2 已发布: 2023/3/7 01:05:19
600个赞,共1,381个帖子。
Check your formula thoroughly.
There is a wrong unit calculation.
Lets give 10mm^2 to x.
This equation won't have a result.
Equation can be calculated with this correction.
Given with units of x is mm^2 of course.
For its to be solved, f(x)=y.
And y should be zero.
And if we plot the f(x) function,
You can see y never gets to zero.
So basically, this equation is not solvable.
With given equation and numbers I say.
