Mathcad to Smath Question
Mathcad to Smath Question - Messages
#1 Posted: 2016/7/26 18:06:01
uncblue
uncblue
2 likes in 18 posts.
I'm trying to recreate a mathcad calculation in smath and I'm not sure how to make the evaluation "l" which is the resultant distance for each point.
Thanks in advance for any help.
C' Bolt Coefficient.sm (9.81 KiB) downloaded 1010 time(s).
DownloadDocumentFile.pdf (8.33 KiB) downloaded 585 time(s).
#2 Posted: 2016/7/26 20:02:04
Ernesto
Ernesto
13 likes in 74 posts.
Here you go. There might be another way to do this, but this was the first I thought of.
C' Bolt Coefficient revised.sm (11.58 KiB) downloaded 986 time(s).
#3 Posted: 2016/7/26 22:55:28
Is that the bolt group ? If so: what else to do ?
#4 Posted: 2016/7/27 11:20:59
uncblue
uncblue
Thanks Ernesto.
@Jean
The next step is to use the C' equation to for each bolt resultant distance to center of group.
I think I've got the C' equation working but I'm sure there is a better way.
C' Bolt Coefficient - 2016-07-27.sm (33.1 KiB) downloaded 1009 time(s).
#5 Posted: 2016/7/27 12:17:10
uncblue
uncblue
"Uncle Sam",
By inspetion, I kind of understand the C' formula,
just a matter to code Smath. Will be back tonight.
What is Δmax ?
Thanks for the help.
Δmax = Maximum deformation on the bolt farthest from the center of gravity.
Empirical set value = 0.34 in
#6 Posted: 2016/7/27 12:52:08
CBG
CBG
78 likes in 312 posts.
you can use the same formula
C' Bolt Coefficient_CBG.sm (13.47 KiB) downloaded 975 time(s).
uncblue 2016/7/29 10:54:00
