1页(6条)
SMath Studio 0.98.6075 (19 August 2016) - 消息
SMath Studio 0.98.6075 available
Latest changes (against SMath Studio 0.98.6073)
- SS-2368: Units don't match issue fixed happened in several cases for numeric calculation;
- SS-2366: Showing of Reference Book and Print Preview windows when SMath Studio shown always on top fixed;
- Plot Region improved for better support of animated graphs created in previous versions of the program;
- Fixed issues with repeated worksheet evaluation started automatically without any user request (usually happened on complex worksheet open or on complex expression paste);
- Symbolic engine: Infinity divided by zero is equal to Infinity now (the same as done for Numeric engine);
- Location of breakpoints corrected on vertical scrollbar when breakpoint(s) set on operands;
- Displaying current stop when calculation paused corrected when stop is on operand;
- Empty Missing Plugins dialog appeared sometimes on file open fixed;
- Meaningless message of Missing Plugins dialog about incorrect version of built-in plugins (MathRegion and AreaRegion) on file open removed;
- Handling of remove Region operation improved (worksheet recalculated if content of focused MathRegion deleted using Backspace);
- Paste of math expression (not a MathRegion itself) from Clipboard do not initiate immediate worksheet recalculation anymore;
- Shortcut key added to Toggle Breakpoint context menu item;
- Interface translation files updated;
- Refactoring.
Download
- Desktop Windows (desktop computer with Windows OS):
SMathStudioDesktop.0_98_6075.Setup.msi (Date: 19.08.2016. File size: 2.04MB) - Desktop Linux (desktop computer with Linux OS):
SMathStudioDesktop.0_98_6075.Mono.tar.gz (Date: 19.08.2016. File size: 1.17MB) - last version of Mono distributive required! - Cloud version (all modern browsers supported):
SMath Studio in the Cloud (Date: 19.08.2016.)
5位用户喜欢此帖子
Davide Carpi 2016/8/19 12:22:00, sergio 2016/8/19 12:42:00, NDTM Amarasekera 2016/8/19 12:50:00, Radovan Omorjan 2016/8/19 14:27:00, frapuano 2016/8/19 14:35:00
What does this refer to:
"Shortcut key added to Toggle Breakpoint context menu item"
Thanks!
Thanks!
WroteWhat does this refer to:
Sure. Screenshot added above.
Thank you.
One other thing I've noticed. When using equal sign to display the result of an equation or variable, I usually want to change the units. I used to hit the right arrow three times and it would bring me to the new units "blank space". Now I have to arrow through all the decimals in order to get there. Was this an intended change?
You're welcome.
Nope, seems I just forgot about this behavior during MathRegion code review. Will check it, thank you.
WroteWhen using equal sign to display the result of an equation or variable, I usually want to change the units. I used to hit the right arrow three times and it would bring me to the new units "blank space". Now I have to arrow through all the decimals in order to get there. Was this an intended change?
Davide Carpi 2016/8/20 14:22:00
Could it be possible then to go to units placeholder immediately when one inserts equal? What's the reason to stay before it?
С уважением,
Михаил Каганский
3位用户喜欢此帖子
1页(6条)
