is this solution correct?
is this solution correct? - Messages
#1 Posted: 2023/6/8 21:04:50
soomoon
soomoon
1 likes in 40 posts.
question_230609.sm (3.75 KiB) downloaded 1086 time(s).
#2 Posted: 2023/6/8 23:35:04
1,106 likes in 1,784 posts.
Obviously not, but the bug isn't that obvious: just avoid to use that 'phi' (j Ctrl-G):
churichuro 2023/6/9 15:32:00
#3 Posted: 2023/6/9 08:08:11
Is this solution correct ?
As given, your function is plain/native. Nothing else applies.
Cheers ... Jean.
#4 Posted: 2023/6/9 08:52:23
597 likes in 1,377 posts.
Is it only valid for Windows?
Linux mono doesn't have this problem.
#5 Posted: 2023/6/9 09:07:42
1,544 likes in 1,859 posts.
Yes, these are different letters:
cos(ϕ) and cos(φ)
maple() works with φ
This was done to unambiguously convert variables into Greek letters:
maple() function uses implicit encoding of Greek letters:
#6 Posted: 2023/6/9 11:58:48
I think the result soomoon expects is this, but it requires a newer version of maple:
#7 Posted: 2023/6/12 01:58:17
soomoon
soomoon
where can i get a new version of maple ?
#8 Posted: 2023/6/12 11:12:20
Inside SMath, you can't. This is a workaround, valid for real values
#9 Posted: 2023/6/12 11:29:29
1,353 likes in 2,264 posts.
Just in case that Maxima is an option. Unfortunately, Maxima requires the user to try specialized simplification functions and doesn't provide a powerful generic simplify.
trigsim.sm (2.43 KiB) downloaded 1056 time(s).
