Triangular Mesh for 3D plots
Triangular Mesh for 3D plots - 消息
#1 已发布: 2021/10/23 02:42:13
1,139个赞,共1,805个帖子。
Hi. There are several variants for the triangular meshs. This is one.
pTriMesh.pdf (459.2 KiB)已下载 915 次。
pTriMesh.sm (29.35 KiB)已下载 1575 次。
2位用户喜欢此帖子
Fridel Selitsky 2021/10/23 03:10:00, Oscar Campo 2022/10/12 08:46:00
#2 已发布: 2021/10/25 03:40:35
1,139个赞,共1,805个帖子。
Hi. Here are some notes about how the mesh is constructed. To include the missing vertices, they would have to be inserted at least twice, when drawing the diagonals. It could be done by constructing the mesh as it is, and instead of drawing the entire diagonal, to the center of the squares, but it could be a slow procedure. For another example, please see https://en.smath.com/forum/yaf_postsm74527_Offset-surface-creation.aspx#post74527
pTriMesh work.sm (28.8 KiB)已下载 1523 次。
2位用户喜欢此帖子
Oscar Campo 2022/10/12 08:46:00, Fridel Selitsky 2021/10/25 03:58:00
#3 已发布: 2021/10/25 21:28:47
1,139个赞,共1,805个帖子。
This other have the intesections as part of the mesh.
pTriMesh_v2.sm (48.39 KiB)已下载 1565 次。
2位用户喜欢此帖子
Oscar Campo 2022/10/12 08:46:00, overlord 2021/10/25 21:31:00
#4 已发布: 2021/11/18 02:12:26
1,139个赞,共1,805个帖子。
Hi. More general mesh utility, with a variable patern. Also, waterfall plots (matlab page here).
pWMesh.sm (193.8 KiB)已下载 1557 次。
pWMesh.pdf (3.2 MiB)已下载 994 次。
2位用户喜欢此帖子
Oscar Campo 2022/10/12 08:46:00, Fridel Selitsky 2021/11/18 08:26:00
